brake question
  • Thread starter Thread starter lmpbzkt492
  • Start date Start date Sep 27, 2006
L
lmpbzkt492
68
  • Sep 27, 2006
what are all you guys running as far as stock replacement brake parts? A few months ago i picked up some hawk ceramic pads and some Trustop rotors from NAPA and ever since i put them on they squeak. Not just every once in a while but all the time? I'm assuming the squeak is from the rotor/pad combo i have being that the rotors were pretty cheap. what kind of pads and rotors is everyone else running as far as stockish stuff goes? also my outer pad is wearing faster than the inner one. i always was told that the inner one wears faster. any ideas??
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 27, 2006
  • Sep 27, 2006
Make sure nothing is rubbing. Also, make sure the caliper can slide/move properly.
90
Michigan insane asylum
Sep 27, 2006
  • Sep 27, 2006
could just be a bad set, that happen to me all four tires squeeked for a week i took them off and took them back.. the place gave me a new set of the same pads and they havent sqeeked since but i have cobra brakes with disk all around but i guess it could happen to any one..
Hi-Po
106
Oslo, Norway
Sep 28, 2006
  • Sep 28, 2006
I am running Steeda slotted rotors, Steeda steel caliper sleeves and EBC Greenstuff pads. Works very well with very little dust and no squealing noises. Definite improvement over stock.
If you do a lot of high speed braking or do track days then EBC Redstuff might suit you better. I am going Redstuff next time I replace my pads.
L
lmpbzkt492
68
  • Sep 28, 2006
when i go to check to see if the caliper slides properly and it doesnt, what does that usually mean as far as stuff i would need to replace or do?
bullitstang1313
713
Indianapolis / Columbus, Indiana
Sep 28, 2006
  • Sep 28, 2006
That could mean that you have a bad caliper, or it could mean that you forgot to take the cap off of the master cylinder. Did you put anything on the back of the pads when you installed them?
L
lmpbzkt492
68
  • Sep 28, 2006
nope didnt put anything on the back of the pads when i installed them. would that stop squeak stuff work? i dont understand the part about taking the cap off the master though?
L
lmpbzkt492
68
  • Sep 28, 2006
i checked yesterday to see if the caliper would slide and it barely moved at all
P
PJB
131
Rotterdam, NY
Sep 28, 2006
  • Sep 28, 2006
Im using Wagner pads on replacement rotors (dont know the brand because they were on there when I got the car).
They dont squeal but the car doesnt seem to stop all that quickly. The rear brakes are fairly new.
sunil6784
620
Boston, MA
Sep 28, 2006
#10
  • Sep 28, 2006
  • #10
The caliper will barely move. The pads are constantly in contact with the rotor, its just a little movement that makes them grab. Sometimes its hard to tell.
Did you make sure that all surfaces are clean? Get some disc brake cleaner and clean the rotors down. Slightly scuff the pads with some sand paper. Some higher quality pads come with an anti-squeal backing pad, like Bendix. Supposed to reduce metal-metal contact. I'm a big fan of Bendix pads.
85ragtop
BTW, I like dudes.
475
123
NC
Sep 28, 2006
#11
  • Sep 28, 2006
  • #11
I replaced my pads with O.E. pads and the squeaked for a few weeks. After that they were fine.
L
lmpbzkt492
68
#12
  • Sep 28, 2006
  • #12
i have had these on the car for a few months now and they have squealed from day one. i guess i should take them back off and just give everything a good cleaning. why would the outer pad be wearing faster than the inner pad? thats what im curious about
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
