brake rattle?
ONEBADPNY
195
FREMONT, NEBRASKA
i just put on new pads on my 99 cobra and now when i hit bumps i will get a rattle in the front end. at first i did not think it was the brakes but then i noticed when i push on the pedal a little bit it will not rattle at all. i checked to see it the rattle clips are in and they are so i am at a loss as of what to do. anyone have this problem?
I had this same problem on my 99 Cobra. Turned out that the anti rattle clips that I installed that came with the pads I got from AutoZone were crap. They were a thinner steel material and they were not even shaped correctly to keep the calipers in there tight. So I ended up taking them off and putting the stock clips back on and that solved the problem.
