Brake & Suspension Rebuild
  • Thread starter Thread starter DuluthFoxbody
  • Start date Start date Nov 9, 2026
1 of 2 Next Last
D
DuluthFoxbody
18
9
Duluth, GA
Nov 9, 2026
  • Nov 9, 2026
My 88 GT needs some work...namely front brakes for sure, rear drum rebuild wouldn't be a bad idea, and some rear shocks. And then of course the ball joints are in rough shape. Since I need to address the ball joints and the rear shocks anyway, I was thinking of refreshing some of the suspension. I would eventually like to do MM rear lower control arms, sway bars, etc. but those may be for a later time. May or may not do caster/camber plates right now.
Anyway, I've seen a ton of different coil spring choices out there and they all seem to be lowering springs...most seem to be a decent amount of lowering. I definitely don't want to slam the car or have it too low. I think the only springs I've seen that are relatively stock height are the Moog ones and lowering springs that aren't too low seem to be the Ford B & C springs. I was kind of leaning towards the Ford C springs, but I've heard the MM road and track springs are good (albeit lower). I'm not racing the car, but I do like to have a bit of fun and throw it around turns. Also, the hatchback has a surprisingly decent amount of room, so I like to carry band equipment at times. I do have an F150 for that, but parking that in downtown Atlanta and squeezing in tight alleyways is a pain. So something that can withstand a bit of weight is good.
I'm considering two options (or a variation thereof):
1) Go slow and retain the stock springs for now and maybe order a set of KYB or something relatively OE and not too expensive for the rear. Focus on the front disc brakes and rear drum brake rebuild and get it stopping. Maybe some Timken wheel bearings. Give it some time and see how it goes. A consideration is whether not those ball joints are shot or can still be driven on for a bit. Afterwards, save towards a nice set of springs and better struts/shocks all the way around (maybe front coilover), some MM lower rear control arms, rebuilt front lower control arms with new ball joints, or maybe some MM tubular a-arms with coilovers. Eventually other stuff like sway bars, etc.
2) Since I need to replace the ball joints and also do the rear shocks, go ahead and order a nice set of decent coil springs with a mild lower, some Bilstein struts/shocks, polyurethane isolation mounts (or is rubber better?), all the brake stuff, and rebuild the front control arms with ball joints. This knocks a lot of it out at once and the Bilsteins might be a nice ride, but I doubt I would be doing coilovers and tubular a-arms anytime soon. But I doubt I really need coilovers and tubular a-arms.
Anyone have experience as to a solid choice for springs that aren't too low might be? Has anyone used the Bilsteins with the Ford C springs and have thoughts? My instinct has been to just fix what needs to be fixed and save for future work. But it sure would be nice not to have to pull everything off again for a while.
AeroCoupe
6,252
4,336
183
Claremore, OK
Nov 9, 2026
  • Nov 9, 2026
So I am a buy once cry once project guy. So hoard parts until you are ready to do the project. It will save time and money in the long run.
Front Suspension:
I would rebuild the stock front control arms with MOOG bushings and some good low friction ball joints. Holstein struts and your choice of springs (I really liked the H&R Super Sports when I had them). Install some urethane sway bar bushings and new sway bar end links with urethane bushings.
The car will lower a minimum of 1” so now is the time for CC plates and just get the MM pieces. They are pricey but it’s a one and done.
Rear Suspension:
MM lowers and new stock upper control arms. Get new MOOG bushings for for the uppers that replace the ones in the rear end. MM makes a tool to replace them but you are only a brake line from dropping g the rear end so just do that and replacing them is 100 times easier. Get new Bilstein shocks and that could wrap it up.
Scope creep warning. While you have the rear end out rebuild the trac lok with new clutches.
You only need front wheel bearings if you need them. Typically they just need the old grease removed, repack them with good wheel bearing grease, and a new seal for the back bearing.
If you do the brakes buy new front soft lines and the rear soft line. They have a tendency to swell internally when they are old.
Reactions: DuluthFoxbody
D
DuluthFoxbody
18
9
Duluth, GA
Nov 11, 2026
  • Nov 11, 2026
Makes sense. Since you mentioned low friction ball joints, I see QA1 has some and of course MM. Although the MM ball joints mention reducing the diameter in the a-arm. I wonder if that means just trying to bend the metal somehow? I'm sure the H&R Super Sports are a great spring but probably a bit too steep of a drop for me. I've seen the Ford B and C springs have less lowering...I know the B springs are progressive and C are linear, but I'm not sure if the Bilstein B6's are well matched for the linear Ford spring rate. I also see some sales for Koni going on and I recall Warhorse mentioning those in some posts.
Yeah, good call on the brake lines, I'm going to get those and bite the bullet on the MM CC plates.
I'm definitely under 400rhwp and not sure what the future holds, but might eventually do GT40 intake/heads and/or a cam. Do you think the MM Sport rear control arms (non or the adjustable ones) are the way to go? Heavy Duty might be extra insurance, but probably overkill. I see where the upper control arms are recommended to be the new rubber bushings, so that's fine.
I know these are wildly different cars, but a long time ago I had a '93 Miata and loved how that handled around the curves at higher speeds. I'm not sure how the Mustang is going to line up when it's all said and done, but hoping to recapture some of that feel.
Thanks for the tips!
nickyb
I gotta say i never painted my nuts, Never Ever
3,068
1,683
163
nevada
Nov 11, 2026
  • Nov 11, 2026
I should have "one and done" like aero said but I first just replaced rotors,drums,wheel cylinders,pads,shoes,and brake lines. Also kyb struts and shocks.
Then I shopped slowly and wisely for the cobra brake upgrade, I got everything (including rims and tires) for under $1800. So choose carefully as your wallet allows.
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Nov 11, 2026
  • Nov 11, 2026
It would cost more upfront, but if you get the adjustable MM (or other brand) LCAs you can fine tune your rear ride height that way?
D
DuluthFoxbody
18
9
Duluth, GA
Nov 11, 2026
  • Nov 11, 2026
Are you still running the KYB's now? What's your impression of them?
nickyb
3,068
1,683
163
nevada
Nov 11, 2026
  • Nov 11, 2026
Yeah still.got them on, I'm looking to do coil overs in the near future so il.get some adjustable ones as I already have caster camber plates.
The KYB s are like stock not an upgrade.
AeroCoupe
6,252
4,336
183
Claremore, OK
Nov 11, 2026
  • Nov 11, 2026
I went straight to the heavy duty MM LCA’s but it was to cover whatever I threw at it later down the road. A lot of people have the ones that allow you to adjust the ride height and they work well.
ustacould
55
61
28
Belmont NC
Nov 11, 2026
  • Nov 11, 2026
Hey welcome. I had to go back and read your history . Nice car doesn't look beat on. I got to rescue a stock '92 a few years ago and the first thing to betray me was the brakes! They were sorry from the factory and time hasn't helped. I got Power stop all around and rebuilt calipers and wheel cylinders from NAPA very affordable and genuine Ford castings. Replaced all 3 flexible lines with braided stainless from NPD catalog, complete with mounting brackets. I used a hand vacuum pump and some thin flexible tubing to pull most of the gunk from the brake resivore, then bled about 2 quarts of fluid thru the lines until it was all clear. You may not need all that. But with that and new tires , damn car felt like a Porsche! Could use all 220 horse power!
Now, there are a lot of really experienced and helpful people on this site and I ain't one of them. But "scope creep" is a real thing - read any build thread. Enjoy!
Reactions: General karthief and DuluthFoxbody
Rdub6
So while I wait to figure out my rear end issues
5 Year Member
Dec 29, 2017
3,977
2,959
153
Long Island, NY
Nov 12, 2026
#10
  • Nov 12, 2026
  • #10
Here’s a visual on the Eibach Pro Kit springs. (Everybody likes pictures)…….. I think it advertised a 1” drop.
I also used the adjustable rear lower control arms from MM…… if for nothing else, it gives the ability to get the back of the car perfectly level. My eye notices the slightest lean, so my OCD needed the adjustability.
Hope this helps.
Reactions: Willybill32, gkomo and DuluthFoxbody
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Nov 12, 2026
#11
  • Nov 12, 2026
  • #11
H&R springs for sure.
I think whether or not you do adjustable rear control arms depends on what you do in the front. If you get coil overs for the front, you can just adjust the height from that end, if you don't, you may need the rear adjustable arms to get the stance you want.
I'd just get bilstein shocks from rock auto, i'm pretty sure they are significantly cheaper there.
Zero chance i fix or work on rear drums, not only do they look horrible, they are just a pain to work with, i'd convert them to discs.
I too am in the buy once cry once category. Doing things twice makes no financial sense, even worse if your available time to do the work starts to shrink (kids sports will put a massive dent in that). Think about, you have the time and money to do it twice, but not the first time?
You are a long way from handling like a miata. No chance you get anywhere near that without a Panhard bar.
D
DuluthFoxbody
18
9
Duluth, GA
Nov 12, 2026
#12
  • Nov 12, 2026
  • #12
The Heavy Duty ones aren't too much more, so that might be worthwhile. I understand the adjustability is for the ride height, but is that for more of racing applications or for tire clearance? Or if lowering springs have a steep drop, is it to raise it to a level you like?
D
DuluthFoxbody
18
9
Duluth, GA
Nov 12, 2026
#13
  • Nov 12, 2026
  • #13
Thanks! Yeah, it seems to be in decent shape. There's a little bit of body work to address, but for the most part it's solid. The brakes are still working (so far), but they're on their way out. Planning to do the same as you, PowerStop and refreshing all the drum hardware with new lines.
Hehe...I definitely feel the scope creep. Every time I consider a fix, there's something else to add!
D
DuluthFoxbody
18
9
Duluth, GA
Nov 12, 2026
#14
  • Nov 12, 2026
  • #14
Hope this helps.
Very nice car!
The drop on those Eibach's doesn't look too bad. Since you have the adjustable LCAs, are you also running coilovers in the front or anything or did you just measure the ride height up front and raise the same in the rears?
Rdub6
5 Year Member
Dec 29, 2017
3,977
2,959
153
Long Island, NY
Nov 12, 2026
#15
  • Nov 12, 2026
  • #15
DuluthFoxbody said:
Very nice car!
Thank you! No coilovers, just the new Eibach springs and KYB AGX shocks/ struts all around.
Honestly the ride height was just about even, and used the adjustability just to tweak it a bit.
I didn’t want the car slammed to the ground either, and after a lot of research, and asking around on this site, the Pro Kit seemed like the best choice, which I ended up being very happy with.
D
DuluthFoxbody
18
9
Duluth, GA
Nov 12, 2026
#16
  • Nov 12, 2026
  • #16
So that's another mention of the H&Rs...
I wasn't really planning on doing coilovers in the front, at least not anytime soon. I really like what Warhorse has accomplished without them, although I'm not doing autocross. Looks fun though. Sounds like the adjustable rears may be the way to go.
Yeah, RockAuto has better prices for those Bilsteins, although Summit did a Beat-a-price on those and there's no shipping. Have them in the cart, but also considering maybe the SA Koni Yellow. Bilsteins are a better price for me though.
Heh...I'm not a fan of drums either, but they will be okay for now. I've done them before on older 60s/70s vehicles and while it's a pain, I'm more concerned with the front for the moment. I would like do to a disc conversion in the future though.
You're right about costs of kid activities, very true.
I know it's not going to be like a Miata. Totally different animal. But thanks for the recommendation on the Panhard bar; I'm sure it's going to be fun to throw around regardless.
D
DuluthFoxbody
18
9
Duluth, GA
Nov 12, 2026
#17
  • Nov 12, 2026
  • #17
Thanks, I'll look into the Eibach set as well. Good info to have!
AeroCoupe
6,252
4,336
183
Claremore, OK
Nov 12, 2026
#18
  • Nov 12, 2026
  • #18
@Rdub6 - what is the tire size on the 10 holes vs the black rims?
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Nov 12, 2026
#19
  • Nov 12, 2026
  • #19
In my experience, the rear springs on the pro kit are too stiff.
I've had at least 6 or 7 sets of springs.
The h&r kit rides much better.
Rdub6
5 Year Member
Dec 29, 2017
3,977
2,959
153
Long Island, NY
Nov 13, 2026
#20
  • Nov 13, 2026
  • #20
They are long gone, but if remember correctly, I’d say 235/60-15.
I’ll have to comb through my old pictures and see if I have anything that show it.
1 of 2 Next Last
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Nov 10, 2026
nfilut43
N
