Brakes Brake Swap
  • Thread starter Thread starter Nightstang00
  • Start date Start date Dec 6, 2017
Nightstang00
133
12
28
Dec 6, 2017
  • Dec 6, 2017
Hello
I’m trying to figure out what I’ll need to swap to all disk and 5 lug setup. I’ll be getting :
94/95 spindles
03/04 Cobra calipers and brackets
03/04 Cobra rotors
Axles for rear (5 lug)
Brake hoses
My questions are:
What year car front struts do I buy
What year brake hoses do I get
Do I need master cylinder, brake booster, proportion valve and what year and car (gt, cobra, v6?
Any help or advice would be appreciated
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Dec 6, 2017
  • Dec 6, 2017
If your car is an 87-93 V8 car, your current struts are fine.
If you are leaving the rear drums, no need to change the MC booster. In fact, there is no proper MC for the setup but the stock MC is close with rear drums.
You'll want to gut the prop vskve with the prop vskve plug, and install and adjustable valve on the line running to the rear drums.
That setup will be prone to locking the front drivers brake before the pass side due to the MC feeding direct pressure to this brake.
Nightstang00
133
12
28
Dec 6, 2017
  • Dec 6, 2017
Yes currently I have a 93 Gt. So If I wanted new struts , I just order 93 gt ones correct? Not 94/95 because it’s the spindles from a 94/95?
I want to have disk brakes in the rear also.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Dec 6, 2017
  • Dec 6, 2017
The struts for a 1993 will work fine on the sn95 spindles.
If running rear sn95 disks, you'll want a 1" bore 1993 Cobra MC and booster to run the 99-04 Cobra front calipers.
Reactions: Nightstang00
Nightstang00
133
12
28
Dec 14, 2017
  • Dec 14, 2017
I got this question from my parts guy on the brake booster Need a diaphragm diameter. It's 7.250 or 8.750. Any ideas ?
Nightstang00
133
12
28
Dec 14, 2017
  • Dec 14, 2017
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Dec 14, 2017
  • Dec 14, 2017
The 1993 cobra and 94-95 SN95 booster are tandem 205mm boosters. That doesn't translate to either dimension you give so not sure what he's looking up. The original fox booster is smaller
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 12:24 AM
Shakerhood
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
