Brake test
  • Thread starter Thread starter gsxrken
  • Start date Start date May 1, 2006
First Prev 2 of 2
T
truck90278
382
Redondo Beach, CA
Oct 6, 2006
#21
  • Oct 6, 2006
  • #21
Just a comment, adding a canister will only give you a reserve of vacuum. If your pulling 10 inchs, that is all you'll get.
rbohm
6,698
550
204
tucson,az
Oct 7, 2006
#22
  • Oct 7, 2006
  • #22
gsxrken said:
rbohm, I'm curious about the pumps you mention. Is it a fan-belt driven accessory, and have you ever seen one used in a musclecar application?
the vacuum pumps from a diesel powered ford truck are engine driven. you would need to fab a mounting bracket for your engine(not hard). as for seeing one in a musclecar application, not yet, but a few engine builders have experimented with these pumps to draw a vacuum in the crankcase to make more power, and the results were promising to say the least(as much as 25 more hp on some big blocks! ). these pumps are also used for running the various vacuum systems on the trucks including the power brakes.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 7, 2006
#23
  • Oct 7, 2006
  • #23
I read an article in a hot rod magazine last summer about using a vaccume pump to increase horsepower just like rbohm is talking about. I've been curious about it ever since. I havn't ever seen anything on how to hook one up or possible donar parts.
rbohm do you know of any specific year/model ranges that come with these pumps ? Since I use a serpentine setup I could put one where my smog pump use to be =)
G
gsxrken
206
Weschester County, NY
Oct 9, 2006
#24
  • Oct 9, 2006
  • #24
jcode68 said:
gsxrken, I'm wondering how this story ended? I have a similar problem (same symptoms you describe) except I'm pulling 18 inches of vacuum at idle, so I'm not sure where the problem lies.
Jcode- I eventually sorted it out. While it was true that my vacuum gauge would show 10 inches vacuum at idle, and more when RPMS increased, my booster wasn't seeing that much. And the reason for that was that I had my booster getting vacuum off the large port on the rear of my double pumper, which also was where I was going for my PCV valve. Turns out the PCV steals almost all the vacuum in this configuration...
I hope your fix is as easy!
First Prev 2 of 2
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
R
Brake Master Cylinder replacement steps for 2016 S550?
  • Reybeast
  • Dec 16, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Dec 21, 2024
89ripper
