- Oct 24, 2017
- 126
- 49
- 48
So I am putting a turbo on my sn95 this winter. The question is how to run the vacuum accessories, most importantly the brake booster?
From all the reading I have done no one seams to worry about it. But, I do plan to autocross, and run it on a track. Also, having had an 11 f150 turbo with a bad check valve (presumably) it's worth concern!
My best idea so far is to plumb it like the f150 with a check valve to manifold pressure, a 'T' and a check valve to prevent turbo intake, and also thinking to run a vacuum Reservoir ( junkyard cruise control part).
Interested in a good dialogue on the subject and what you are running. Or will the consensus be running a vacuum pump? Also A Venturi hose off the header has crossed my mind but doubt it would have much to offer?
Thanks for aNY input.
