will a 15 inch wheel fit the 11.65 cobra brakes? the wheel I have is a 15x8 weld prostar any help would be appreciated
wicked93 said:thanks, this is kinda the deal that I am inI bought a rear end from foster auto wreaking in portland drove all the way up there paid the money and they ended up not having the rear since it got tore down and not taken out of the computer and then they say that they had one in salem and I could pick it up the next day at the salem foster's auto wreakers so I drove over there and when I go to pick it up they had stripped the calipers and brake lines off I told them that I paid for a complete rear end and they said that they always strip the calipers off for cores well napa wants $86.oo each for cores and ford wants $80.oo so I have been tring to get ahold of the guy that I dealt with at foster's talked to him once and not heard anything back yet all that I am asking for is the money back for the core charges nothing else I will spend the money for the brake lines I am tempted to return the damn thing and get one from bob's ford over by krazy koncepts.
WaterPog said:it just depends on the wheel, some will some won't. The first set of steel wheels that I had (the ones will ended up with) needed a 1/4" spacer and some minor grinding on the caliper. The set I was running last year and the year before fit fine w/o any spacer and would have fit w/o the grinding. Both were 10" wheels with 6.5" backspace if I remember correctly. The first ones may have been smaller though, it's been a long time.
I've got a set of draglights in the garage right now that I still need to test fit, but they have a very small drop center and should clear w/o issue.
Edit: I just went out and test fit the draglights and they clear fine w/o spacers. My calipers are allready clearanced though so I can't say for sure if they would fit normally but my guess is that they would.
WaterPog said:In the rear the cobra caliper is the same as the GT (if we're talking '94+ stuff, not sure about the '93) the difference is in the rotor and the caliper bracket.
