Brakeline question?
1973mach1
457
PA
I replaced my master cylinder, all new front disc brakes and my brake line on my drivers side and bled the brakes and all. But now im thinking I should replace the brakeline on my passenger side, if I replace that line now would i have to rebleed the master cylinder? Or could I just add the new line and just bleed that wheel?
Thanks,
Jim
as long as you dont disconnect the line from the master cylinder to the balancer you wont have to bleed all the brakes, just disconnect the line from the balancer to your brake calipers so you only have to bleed that one line and not all the other lines
