  • 1994 - 1995 Specific Tech
brakes squeeling
  • Thread starter Thread starter HazMat404
  • Start date Start date Jan 15, 2004
H
HazMat404
1,749
Jan 15, 2004
  • Jan 15, 2004
alright....my back left brake is squeeling. the pads look fine and the rotor looks decent (just cleaned both sides and they were new about a year and a half ago). it squeels when i am stopping (not too bad) but when i start up and let out the clutch, i hear that brake rubbing pretty bad.
now what should i check/clean back there to make this stop?? should i get my rotor's turned?? im just sick of it but dont know what else to do to fix it
R
rockin_rick
968
Jan 15, 2004
  • Jan 15, 2004
Perhaps your hardware is rusted/dry and sticking. The caliper has to be able to float side to side over that caliper to evenly apply pressure to both sides. Often the slides get corroded and stick. This could be your problem especially if it's sticking when you are just getting going.
Rick
viperos
2,943
Bellevue, WA (yes, the land where every 16 year o
Jan 15, 2004
  • Jan 15, 2004
take off the wheel, and the brake pads, and the rotor, then use very fine sand paper on the pads, and use some Brakeleen on the rotor, blow off w/ a compressor or something, and apply some Squeak Relief product to the entire rotor, inside and out... the reasemble, and the squeak should be completely gone... I swear by that stuff... never had a problem w/ it either... lasts about 10K miles before mine start to squeak again...
H
HazMat404
1,749
Jan 15, 2004
  • Jan 15, 2004
so you think i need to go in and do some maintence on my rear caliper that is making the noise?? i got a haynes so it would be an easy step by step. just dont want to have to go through all that. ill try that aint sqeak stuff. i already cleaned off the rotor on both sides and cleaned the pads off with some brake cleaner. ill try some of that anti-squeak and ill let ya know how it goes. thanx
viperos
2,943
Jan 16, 2004
  • Jan 16, 2004
you never want to use cleaner on the pads... that is probably why they are squealing now... the pads absorb the cleaner... and never really get rid of it... bad news down the road...
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
