brakes
  • Thread starter Thread starter ride410
  • Start date Start date May 12, 2005
R
ride410
77
Chicago, Illinois
May 12, 2005
  • May 12, 2005
Where can I find a cheap five lug conversion kit. PLEASE HELP!
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 12, 2005
  • May 12, 2005
THis was discussed earlier ... if you are looking for a new kit then check out 5.0 resto. Keep in mind they give you 5 lug rotors and not the SN95 spindles so wheel fitment may be a problem depending on your choice. Can always do the junkyard SN95 front and ranger/aerostar rear stuff as many have already done. Good luck.
old_blue
1,783
282
124
May 12, 2005
  • May 12, 2005
I am currently doing the 5-lug conversion with the junk yard method. I hardest part is getting the rims at this point... I didnt realize bullit rims were so expensive.
R
ride410
77
Chicago, Illinois
May 12, 2005
  • May 12, 2005
would I be able to use 16 inch rims still? Thanks for the replies
old_blue
1,783
282
124
May 12, 2005
  • May 12, 2005
i say yes, but it all depends on the brake upgrades you wanna perform. If you are going with bigger calipers then you might have to go with 17's. I am going with 17's when I can afford it. If you are going to use stock sn95 calipers then I think you are fine with 16's
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
May 12, 2005
  • May 12, 2005
the easiest and almost cheapest is the 50 resto kit for 400. you get new parts and everything. The absolute cheapest way to go is the junk yard route. you can get the kit stuff for less but itll be used.
This way will not enable you a brake upgrade, and you wont be able to run certain wheels.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
