Braking In Engine???
  • Thread starter Thread starter FordGuy88
  • Start date Start date Apr 27, 2008
F
FordGuy88
241
Park Ridge, IL
Apr 27, 2008
  • Apr 27, 2008
I was wondering what type of oil I should use when braking in a new engine? I have heard to use a non synthetic, but was just wondering what you guys think. I already know the whole braking in process, and just wondering about the oil.
Thanks,
Dave
Fast63
717
  • Apr 27, 2008
Is this a roller cam engine? If so, just use a non-synthetic normal motor oil. If you have a flat tappet cam, I recommend delo-400 diesel oil, it's 15W-40.
capri debris
289
PA
Apr 27, 2008
  • Apr 27, 2008
"Braking" is what you do when you want to stop... "breaking in" is what you mean.
Break it in with whatever oil you plan on running in the car, just change it and the filter after about 100 miles and again after 500 miles. Don't rev the engine too high, but don't be afraid to give it full throttle... a good load on the engine is what helps seat the rings. Good luck and enjoy your new engine.
88mustang92
105
  • Apr 27, 2008
If the motor is flat tappet i would first break it in on valvoline rv-1 racing oil with the extra mineral in it to help the cam bearing break in easier but only do this for the first 30 miles or so otherwise after that i would use 10 - 40w just for extra protection, just my thoughts
vikingpower
656
CWU Ellensburg, WA
Apr 27, 2008
  • Apr 27, 2008
anything special needed for moly rings?
F
FordGuy88
241
Park Ridge, IL
Apr 27, 2008
  • Apr 27, 2008
It is a roller engine. Thanks guys. I think I found the perfect oil.
ATISTANG
104
  • Apr 27, 2008
10w-30 or 10w-40 cheapo motor oil is what i would use for the first 500miles because you should change it a few times in this period
i wouldn't run synthetic until you have broken the engine in and taken it to red line a few times with someone behind you to see if there is any blue smoke or not
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
