Brand-new Edelbrock heads complete for under $900 shipped!
Maryland Stang
1,656
30
39
Greenville, NC
Has anybody seen the new Edelbrock E-Street heads? They can be had for under $900 shipped. 1.90 or 2.02 valves. Non emissions. 60CC. Up to .550 lift springs. 7/16 head bolts. 3/8" studs with guides. 40 pound weight savings.
I wish they had these before I had my P heads built. I would be sporting these instead.
I am curious about these heads as well anybody purchased them yet? I wonder if they are the same as the 603719 casting that they sell for around $1100 -1200
Brand Edelbrock E-Street Cylinder Heads
Manufacturer's Part Number 5023
Part Type Cylinder Heads
Product Line Edelbrock E-Street Cylinder Heads
Summit Racing Part Number EDL-5023
Cylinder Head Style Assembled
Cylinder Head Material Aluminum
Cylinder Head Finish Natural
Combustion Chamber Volume (cc) 60
CNC-Machined Combustion Chamber No
Intake Runner Volume (cc) 170cc
Exhaust Runner Volume (cc) 60cc
CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner No
Intake Port Location Standard
Exhaust Port Shape Square
Exhaust Port Location Standard
Spark Plug Style Straight
Intake Valves Included Yes
Intake Valve Diameter (in) 1.900 in.
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.600 in.
Valve Springs Included Yes
Maximum Valve Lift (in) 0.550 in.
Outside Diameter of Outer Spring (in) 1.250 in.
Damper Spring Included Yes
Number of Springs Per Valve Single
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Valve Stem Seals Included Yes
Valve Stem Seal Style Umbrella
Rocker Arm Studs Included Yes
Rocker Arm Nut Thread Size 3/8-24 in.
Rocker Arms Included No
Rocker Arm Nuts Included No
Guideplates Included Yes
Guideplate Pushrod Size 5/16 in.
Valve Cover Mounting Style Perimeter bolt
Accessory Bolt Holes Drilled Yes
Valve Guides Included Yes
Valve Guide Material Manganese bronze
Valve Seats Machined Yes
Valve Seat Machine Style 3-angle
Valve Seat Material Powdered metal
Steam Holes Drilled No
Oiling Style Through pushrod
Machined for O-Ring No
Heat Crossover No
Quantity Sold as a pair.
Notes Designed for use with hydraulic camshafts less than .500 in. lift. Requires use of hardened pushrods. Part number 9680 head bolt bushing kit required for use with 7/16 in. head bolts.
I picked up a set of these, going to be running them with a tmoss cobra intake and a Tfs stage 1 cam. Price was great main reason I got them cause I was thinking of getting some thumpers but for 150$ more get Alum heads cant beat that. They will be going on in a few months will let everyone know how it turns out. In the mean time if anyone else has any numbers with these I would like to see how they perform.
