Brand new FMS Starter wont work
dderek
180
just finished swapping the entire drivetrain.
tko 600, centerforce clutch, fms billet steel flywheel, fms alum. driveshaft, new bellhousing, new fms hi torque mini starter.
got everything back together, thought i wired the starter right.. it cranked the first 3-4 times i tried it, but wouldnt start.. but i knew my timing was off. so i kept getting out and twisting the distributor to different spots figuring that would help. then i go to crank it. and just *click*. nothing else turns off. everything else keeps power, but it wont crank over, just clicks once at me.
Ive tried a few things to try and fix this, or cancel out a few problems.. but nothing has worked.
1. Tried turning the motor over a little bit by the crankshaft bolt with a socket wrench.. thinking it might be stuck, etc.. didnt help.
2. Tried swapping the starter solenoid from my wrecked coupe in. I knew that car started.. Same click, nothing changed.
3. Tried charging my battery for about 20 hours. Didnt help.
4. I noticed i had the wires backwards from the instructions. the small black wire was on the side of the relay that the positive battery was on, and the thick red/black was on the other side. Swapped those back. Still clicked... Did i fry a wire?
What pisses me off is this starter is BRAND new. it shouldnt be doing this to me. and after alllllll that work i did on the drivetrain in my driveway, what a pain:Damnit: . Im just dying to drive it, and hope all the bad vibrations are gone (had a warped flywheel), and bad throwout bearing.
Also, the instructions with it dont really match the starter. it tells me to put one wire on a blade connector. but there wasnt one on the starter. and no blade connector on the supplied wires.:shrug:
So i wired as i figured it should go.
btw. the part number for the starter is 397-M-11000-A50..
incase some of you have the same one, and maybe know what im talking about?
Thanks for helping
Derek:shrug: :flag:
ps. i refuse to attempt the "whack it with a big ****ing hammer" technique.
Sounds like you may have fried the solenoid on the starter. This would make sense since you aplied a constant 12V to it instead of a switched 12V.
Make sure that you have a constant 12V at the starter on the thick red/black wire, and that you are getting 12V on the smaller wire when you turn the switch to start.
Mario
