I just put in a SPEC Stage 2 clutch with my new engine. I used the T/O bearing that came with the clutch and installed a new steel T/O bearing retainer on the tranny. For the first 200-250 miles, there were no problems other than some coolant leaks here and there. Recently while driving the car, there is a loud ticking noise comming from the clutch when the clutch petal is depressed. The noise is not always there. It only seems to do it after I go WOT. And after letting the car sit for ~10 min, the noise is gone! What is causing it? I have a little over 300 miles on it now. With the clutch in, the ticking speeds up and slows down with the engine speed. The clutch and t/o bearing are both brand new so I don't see why it would make any noise.
Thanks,
Clay
Thanks,
Clay
