  • 1994 - 1995 Specific Tech
Breaking in a Tremec
  • Thread starter Thread starter 95strokerPSU
  • Start date Start date Jul 30, 2004
95strokerPSU
986
Sacramento from Philly
Jul 30, 2004
  • Jul 30, 2004
I read on www.5speedtransmissions.com that you should intially fill your Tremec 3550/TKO with a high quality ATF and then after 500-700 switch to Synchromesh. Did anyone do this or is this a waste of time and I should just go with the Synchomesh to begin with?
Nik_95Cobra
1,677
Tempe, Arizona
Jul 30, 2004
  • Jul 30, 2004
I Just went with the Synchromesh Right off the Bat per sellers recommendation.
jwalker
405
millersville,pa
Jul 30, 2004
  • Jul 30, 2004
same here
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 31, 2004
  • Jul 31, 2004
I've run standard ATF and Synchromesh in Tremecs before, the Synchromesh is signifigantly better feeling. I'd just go for it right off the bat. The manual calls for either but reccomends the GM stuff.
95strokerPSU
986
Jul 31, 2004
  • Jul 31, 2004
Synchromesh it is then..thanks
Killercanary
The car that set the bar.
Altoona, PA
Jul 31, 2004
  • Jul 31, 2004
Yep, go synchromesh right off the bat. Don't powershift, speed shift, or downshift the tranny for the first 500 miles too. BEfore shifting right into reverse throw it into 5th and then come back into it, this is donw because reverse doesn't have any synchros and it will someimes grind if you try and put it in reverse too quick, putting it into 5th slows everything down enough that it willl go right in.
SlowGT
826
Columbia Co, PA
Jul 31, 2004
  • Jul 31, 2004
This is all good info. I've always run Mobil 1 ATF in T5s and Tremecs. Based on these posts, I believe I'll be trying out Synchromesh with the new TKOII. I know this wasn't my thread, but thanks for the tip just the same
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
MSPNP2 Closed Loop Initial Values
  • Gibson17
  • Mar 14, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 21, 2025
Gibson17
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
