Brodix T1 Heads 195cc on a SBF..Any good?
Manewaymja2
245
Hey Guys
Any of you using Brodix T1 Heads out there on your SBF say on a 331 to 347 with a Solid Roller Set Up?
If so any realy good numbers?
They have a competion Valve Job, 2.080/1.60, 1.550 Roller Springs, 240 closed 540 open, 68cc chamber. Its what you find on line with a bit more work. Along with a Solid Roller Lifter set up.
I would like to know your opinions as well as experience.
Thanks
I dont know anyone using them but brodix has a good name for making power and i think they will work well, what solid roller are you going to use? chances are if you go custom with the cam the grinder will tell you what springs you need
Thats good news, the Heads aremt exactly fully ported but the flow numbers were pretty good. The Cam is a custom cut Cam, still waiting on full details as the Cam details were given to the heads builder so he could make the heads compatiable.
Should have the specs shortly.....Will be using on a 347 SBF with a D1 set up.
