  • SN95 4.6L Mustang Tech
Broke the Radiator Drain Nut Off...
  • Thread starter Thread starter bryan0
  • Start date Start date Aug 1, 2007
bryan0
175
Bethel, CT
Aug 1, 2007
  • Aug 1, 2007
Stupid me...
I got carried away while tightening the plastic nut that you loosen to drain the coolant from the radiator. The stem of the bolt is still in there and it's obviously tight enough, so there's no leaks. I'm not in a rush to get it fixed, but I want to get the stuff so I can do it when I have the time.
Has anyone been through this before? I didn't look too much, but it doesn't look like it'll be too too bad. Does that plastic bolt come all the way out if you keep turning it? I could get a left-hand-thread screw and try taking it out like that if the whole thing just comes out.
Any help would be great.
Thanks
the98stang
2,408
Clovis, CA
Aug 1, 2007
  • Aug 1, 2007
bryan0 said:
Stupid me...
Thanks
I did the same thing. Left that **** right in there .
Just use the radiator hose to drain the coolant if you ever need to drain again.
SilverBullet00
1,150
Wichita, KS
Aug 1, 2007
  • Aug 1, 2007
When I broke mine off I realized there was a hex hole through the plastic nut. So when the nut broke off there was still a little bit of the hole left where I could use an hex key to remove/install the drain plug. Check it out, yours may be the same... That was on a 2000 GT
40th GT
916
Lawrenceville, GA
Aug 1, 2007
  • Aug 1, 2007
I did the same **** too. I didn't realize the plastic was that weak and I tightened it too much. I just used a wide flathead screwdriver to turn it.
96GTstang46
142
Seattle, Washington
Aug 2, 2007
  • Aug 2, 2007
You mean to tell me that people DONT brake this off???
Yea i just take the raditor hose off.. its not like you have to do it offen (hopfully) otherwise, i think that screwdriver trick might work.. im going to try it next time.. lol thanks 40th GT
nyuk98gt
1,427
Chesterfield, MO
Aug 2, 2007
  • Aug 2, 2007
A new one costs under $10 (at the Ford parts counter). Remove the remaining piece (the far end is split and has barbs on it but it can be pulled out) bye loosening it until you can grab the remaining part with needlenose pliers. Basically, the drain c*ck (yes, that's what it is called) is loosened completely first and then, if you want to remove it, you compress the shaft to let the barbs pass through the opening. The reason the barbs are on there is so that the drain stays in place but allows coolant to come out.
HTH,
Chris
Blinkstang
316
Chicago, IL
Aug 3, 2007
  • Aug 3, 2007
I did the same thing when I broke mine, haha. Picked up a new one at Murray's for like $4.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Aug 3, 2007
  • Aug 3, 2007
Wow, i did the same damn thing. OH well, i just forgot about it since i don't plan to drain my radiator every month.
DTNODYA
831
  • Aug 3, 2007
I have to join the "I thought I was the only one who did that" club ...
I bought got a new one from autozone .. it was cheap
bryan0
175
Bethel, CT
Aug 3, 2007
#10
  • Aug 3, 2007
  • #10
Wow, I'm glad to see I'm not the only one!
Thanks for your help guys, it doesn't look like it'll be too bad after all.
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Sn95 new style hub retaining nuts
  • limp
  • Mar 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2025
limp
