  • SN95 V6 Mustang Tech
Broken Battery Connector
  • Thread starter Thread starter beary58
  • Start date Start date Jul 25, 2005
beary58
69
  • Jul 25, 2005
Any easy way to replace the conector without replacing the whole cable? Is the cable hard to replace?
Thanks for any help.
2000 White Vert
beary58
69
  • Jul 25, 2005
Oh forgot, it's the "negative" terminal.
ChingonStang
308
Dallas, Tejas
Jul 26, 2005
  • Jul 26, 2005
Most people would say to replace the cable, but you should be able to find a connector at Autozone to replace it.
mustangmat99
167
  • Jul 26, 2005
yea..autozone definately has terminal connectors
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Pcm ground connector
  • fox1990
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 12, 2026
Mustang5L5
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
86 gt replaced fuel pump won’t prime / amp drops in key on position
  • 4eye86fox
  • Jan 10, 2026
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
