Broken rockers???? split in two
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
My uncle's car broke a rocker? It's a stockish 302, ('72 closed chamber heads, stud mount rockers cast metal, 500 lift cam). The rocker just snapped in two and the push rod is not bent (isn't a hardened pushrod either).
Anyone ever see this?
My '65 keeps breaking them. I'm assuming they are the cheap, cast, canoe shaped ones like on my car. I just keep replacing them as they break. The new ones never fail......I think I've gone through 3 since I've owned the car.
Yup they are the canoe shaped ones... I checked everything on the engine, no water leaks, no jammed valves, no bent push rods, everything is fine. The valve springs are a lot stronger than stock so I guess the rocker just broke due to too much load?
Well I got some 1.6 full roller rockers for him from Crane.
I once shoved a pushrod through a rocker on my old 440 Challenger. Never quite sure how it happened but I have not seen one break. Though it doesn't seem to be a new problem if nkau has had the same issue 3 times now.
