  • SN95 4.6L Mustang Tech
Broken Speedometer question
  • Thread starter Thread starter Koa04
  • Start date Start date Aug 24, 2008
K
Koa04
55
Hawaii
Aug 24, 2008
  • Aug 24, 2008
I've searched the threads and found some info on this but still have some questions. Here's some background.
My speedometer just stopped working a few weeks ago. No weird movement of the needle or anything. Started the car, started to drive, no speedometer, period. I wasn't doing any work on the car at the time or prior to the malfunction.
Odometer works fine as does all other electronics in the car (with the exception of a slight engine feedback through my speakers). I also run a vehicle dynamic processor through my flat screen which shows some vehicle output (MPH, Tach, Lateral G's, etc) . The speedometer portion of that device works O.K. but has never been super accurate. I believe this device is attached into the speed sensor. This processor has been hooked up for several years prior to the speedometer failure. One last bit of info... I have aftermarket gauges in for a few years as well. They are autometer (Roush Style) gauges. They have about 20,000 miles on them since their install. I doubt they are bad.
Where would I start troubleshooting?
K
Koa04
55
Hawaii
Aug 24, 2008
  • Aug 24, 2008
Any ideas?
00stangv6lr
61
Omaha, NE
Aug 24, 2008
  • Aug 24, 2008
I had problems with my speedo. I have aftermarket guages as well. I made the problem go away by replacing the ground that goes from the motor mount to the frame. Its under the car on the driver side. Hope that fixes it.
K
Koa04
55
Hawaii
Aug 25, 2008
  • Aug 25, 2008
I'll give that a shot in the morning. Thanks
StangIt #1
203
Washing the Car
Aug 26, 2008
  • Aug 26, 2008
Koa04, did replacing the ground also fix your problem? The Tach in my '98 stopped working (for the most part) about 3 years ago. It will randomly work "normally," but is generally pegged @ flatline. My gauges are OEM.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
D
Speedometer problem
  • docinatl
  • Sep 14, 2023
1965 - 1973 Classic Mustangs -General/Talk- Nov 10, 2023
70mstang
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
