broken water pump bolt help
bluidvl
63
delaware
ok bought a march pulley kit took off power steering pump and was bolting on bracket for idler pulley water pump was missing bolt.turns out bolt is broke in block .i can slide new bolt so far but not enough to catch threads what should i do help:mad:
i would drill the center of the bolt out for a easy out. then i would make sure i got some sort of penitrating oil around the bolt threads. liquid wrench works very well. let that sit for a while . then before i went to use easy out i would heat area around bolt with heat. basically heat block up not the bolt. then use easy out to remove the bolt. hopfully this works for yah.
Here’s the parts list for the broken water pump bolts. Not cheap, but it will get you fixed and back on the road…
A word about the links, if they don’t work, do a search on the part number (P/N). MSC updates their catalog regularly, and the pages may change, but the part numbers don’t. You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1096 Use drill bushing 5/16” OD, 5/32” ID, ¾” long, P/N 07010457, price $8.57 This centers the drill bit in the housing bolt hole so you don’t get off center and damage the water pump, timing cover housing or engine block
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=27 drill bits - use 5/32” Cobalt/TiN coated bit. P/N 78530433, price $3.91
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1928 Screw/bolt extractors. Use EZY-OUT Screw Extractor P/N 63760037 Price $2.67
One step specialty item: See Drill-Out® Broken Bolt Extractors drill bushing, reverse twist drill & extractor all in one unit. Best to use when the bolt breaks off with the remaining part below the start of the threads. .P/N 05027164. Price $18.33 each. You MUST have a reversing drill motor (either air or electric) to use this bit. http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=19268
A long shank tap should be used to chase the leftover metal out of the original threads. Also recommended to clean the corrosion and dirt out of the threads before you reassemble everything. Cleaning the threads will help prevent the bolts from seizing next time (yes, there will be a next time).
Long shank 5/16” taps
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=279 5/16” pulley tap, 6” shank P/N 04801189 price $14.26
OR second choice, will not clean all the bottom threads unless you grind the end of the tap.
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=2798 extension tap, 6” reduced diameter shank P/N 04701181 $16.17
See http://www.windsorfox.com for Stainless Steel Water Pump Bolts with Custom stainless steel studs. Allow the use of factory accessory brackets without hunting for obsolete parts or using spacers.
Kit comes complete with nine polished stainless 12 point bolts, four stainless studs and nine stainless oversized washers.
Price: $65.95
