Bucking as throttle engaged
  • Thread starter Thread starter sgw_88FoxGT
  • Start date Start date Jul 8, 2008
sgw_88FoxGT
43
  • Jul 8, 2008
I'm pretty new to Mustangs and I just got my first 5.0, an '88 GT a couple months ago so I'm kinda learning as I go. Anyway...
No matter what gear I'm in, right when I first engage the throttle my car will buck real hard if the clutch is fully engaged. If it's right at the point where I just barely tap it it's almost like it's giving it either too much gas or none more than if it was idling, like it can't decide and it'll buck back and forth until I give it just a little more gas. The bucking doesn't happen when I stomp on the gas and it doesn't happen if I'm cruising at 1500 rpm. It usually happens if I'm trying to accelerate really light as I'm going through second and third gears between 1500 rpm and 3000 rpm.
Only mods to the car is straight pipes (2.5 inch, no H- or X-pipe, no cats, Magnaflow mufflers) and a King Cobra clutch. I replaced the fuel filter, cleaned the IAC, tried resetting the EEC by disconnecting the battery for 20 minutes then reconnecting it. I can't find any vacuum leaks but I may just be overlooking a leak.
Other symptoms are the occasional hanging idle at about 1500 rpm but it'll always, sometimes slowly, come back down to 900 after warm up. Once in a while my idle surges barely noticeably, like 50 rpm but hangs out around 900 rpm.
Any ideas?
Thanks in advance! I can't anyone else with this specific bucking problem right when the throttle is engaged!
sgw_88FoxGT
43
  • Jul 9, 2008
Could it be a bad fuel pump?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
