Build ideas?
  • Thread starter Thread starter MikeUrban
  • Start date Start date Nov 24, 2010
First Prev 2 of 2
1bad67sbf
674
N. VA
Nov 30, 2010
#21
  • Nov 30, 2010
  • #21
here is my motor for my 67 and i have 5 grand in it including purchase of the motor before the mods i did to it.
ReefBlueHatch
682
96
39
Central KY
Dec 2, 2010
#22
  • Dec 2, 2010
  • #22
A few months ago I priced a TFS top end kit and then the supporting mods I'd need and for everything new was right at $4k. I would need a TB, 24 lbs. injectors, fuel pump, regulator, tube for my C&L, lifters, long tubes and a X-pipe. Then I'd have to pay for a tune.
MikeUrban
187
Chantilly, VA
Dec 3, 2010
#23
  • Dec 3, 2010
  • #23
I thought the TF top end kit came with lifters. If not, which ones should I get?
Rick 91GT
Mustang Master
95
99
PA
Dec 3, 2010
#24
  • Dec 3, 2010
  • #24
The TFS top end kit doesn't include lifters, the Ford Racing units are under $130 and work just great.
Here is the list of parts I'd plan to use with the top end kit...
Ford Racing Lifters
Waterpump
70mm TB, I like Accufab, Holley and Wilson
MAF (see note below)
24# inj
190lph-255lph fuel pump and new fuel filter
1-5/8" headers, shorties
X-pipe ( I see your in VA so if you need to pass emissons you may want to consider a high flow cat pipe or youll be swapping the offroad pipe out)
Good quality cat back
AFM Power Pipe or another high flow intake pipe set-up
spark plugs
spark plug wires
new cap and rotor
If your planning on boost down the road, try to decide Turbo or Supercharger. If Supercharger I'd get the PMAS 95mm meter, if turbo get the 75mm bullet and upgrade to a blowthrough meter when you swap the turbo on). Save for the aftermarket block and then add the power adder
MikeUrban
187
Chantilly, VA
Dec 4, 2010
#25
  • Dec 4, 2010
  • #25
I'm just going to keep on saving . I have nothing else to put my money into right now any way. I should be able to afford everything by late spring. Thanks for all the awesome input everybody. I think I'm going to go with the top end kit, and then later on I'll get a good short block, throw everything onto it, and go with a supercharger. I'll be back with all of the questions that go with that later though!
First Prev 2 of 2
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
