building a 347 what intake???
  • Thread starter Thread starter aod92
  • Start date Start date Oct 28, 2007
aod92
104
  • Oct 28, 2007
I'm building a stock block 347 with a coast rotating assembly. I have a set of ported trick flow tw heads that flow just under 300 cfm. The intake i have is the trickflow street heat. Is that intake gonna be to small? If it is what intake do you guys suggest? Also what kind of numbers should i expect with this 347 and my ported heads to the rear wheels? It is going thru a c4 trans. Thanks!
giddyup306
3,041
Oct 28, 2007
  • Oct 28, 2007
300 CFM should make a stout 347! When you start flowing around that much though you might sacrifice torque down low or run into some driveability problems in a street car.
I'd go with a TFS intake or a Performer II intake. Stay away from cobra or explorer type intakes.
It's hard to say how much power you'll make. It depends a lot on the cam and CR.
You should be able to make 400 RWHP pretty easy with the right cam and a good tune.
RYC CUKR
1,437
Orlando
Oct 28, 2007
  • Oct 28, 2007
I am gathering parts for a similar combo to yours. I am going to run my TFS trackheat and see how it does.
MrXCESSIVESPEED
Maryland
Oct 29, 2007
  • Oct 29, 2007
TFS R would get my vote....
Rick 91GT
Mustang Master
95
99
PA
Oct 29, 2007
  • Oct 29, 2007
Really depends on the cam, CR and intentions of the car....
With a healthy cam and shifting above 7000rpm with a 4:30 gear or so I'd look into a Victor 5.0 or a ported Holley SysteMAX II. If your more street car oriented I'd look into a box stock Holley or RPM II, or even the TFS-R.
Whats the entire combo? Whats the weight of the car? 5spd or Auto? Rear Gear? Exhaust size?
ninety15.0
1,336
  • Oct 29, 2007
Yea i think we need to know a little more about the combo/intentions for the car. Is this going to be a street or strip car? How streetable is acceptable for you? What kind of converter are you looking at running? What gear?
I think you are going to want a very healthy intake if your heads flow that much. Definitely something like an RPM II or a systemax II. The TFS-R would work...even a TFS box.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 29, 2007
  • Oct 29, 2007
I see three issues of a little concern:
- Stock Block
- Revving past 7,000
- Potential to make 400+ rwhp
The power output will depend on compression, camshaft, accessories, attention to detail, and engine builder.
Otherwise, I like the Holley myself.
aod92
104
  • Oct 29, 2007
The rest of my combo is an anderson b31 cam, c4 trans 4000 stall, 3:73 gear, and all the bolt crap you can buy. The car is not a daily driver, it is a street /strip car that sees more street but only on nice sunny days. With everything i have last year the car went 11.67@112 with a stock shortblock with 140K miles on it.
egan_gt
37
hibbing MN
Oct 29, 2007
  • Oct 29, 2007
Im running a typhoon on my 347 w/ AFR 185s and a Z cam. Probably wasnt my brightest idea to run a typhoon, but money was short. From what Ive read, Im thinking of going with either a Holley or a TFS intake?
aod92
104
#10
  • Oct 29, 2007
  • #10
What kind of numbers does your car put down?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 29, 2007
#11
  • Oct 29, 2007
  • #11
A stock Victor 5.0 will feed that, TF Box or you could go with an EFI conversion like Victor Jr. An R is a good long runner for it as well as a ported Holley SMII.
egan_gt
37
hibbing MN
Oct 29, 2007
#12
  • Oct 29, 2007
  • #12
It made 310 hp/ 340 tq. That is with no tune and I was going way lean at WOT, like 16:1. I am running 30lb injectors w/ a 255lph pump and the fuel pressure was at 42lbs with the vacuum line plugged in.
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 29, 2007
#13
  • Oct 29, 2007
  • #13
ported Systemax intake gets my vote
88mouse
630
Mooresville nc
Oct 29, 2007
#14
  • Oct 29, 2007
  • #14
- Stock Block
aren't all the TF intakes the same? I thought the trackheat and the R just had more port work done to them.
Buddy of mine is running the holley and it make very good power.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 29, 2007
#15
  • Oct 29, 2007
  • #15
This is going off memory, but if I recall the TFS-R has an 11.5" runner while the trackheat has a 12" runner. The ports at the head are the same, but the TFS-R is larger "up-top"...
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 30, 2007
#16
  • Oct 30, 2007
  • #16
bingo 5 spd if you look on there website they have one lower
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 31, 2007
#17
  • Oct 31, 2007
  • #17
The TFS R lower is NOT the same as the street/track lower. Had both, been there/done that.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 31, 2007
#18
  • Oct 31, 2007
  • #18
According to trickflow the port dimensions are the same at the bottom, but larger on top, where the upper meets the lower..
My reference above was to the lower intake alone if there is any confusion.
M
Mr. Scary 5.0
10
#19
  • Oct 31, 2007
  • #19
depends on gear, and rpm range. I would shoot for either a TFS track heat or Edelbrock RPM II, these make great power in the 1500 to 6500rpm range.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
