Building a 351 stroker.
  • Thread starter Thread starter Shadrack
  • Start date Start date Dec 9, 2005
Shadrack
95
  • Dec 9, 2005
Guys, i'm about ready to buy a 351 block, and i'm looking to have a killer N/A setup. All the power adder stuff is just too easy. (Not meaning to offend anyone. )
Here are my plans, but I honestly don't know much about matching the right heads/cam/stroker kit for the best performance. I'm mainly struggling about the cam.
Stroker kit. 351 stroked to a 408 (Forged rods and forged dish pistons)
Stroker Kit
Heads AFR 205's assembled (like you buy from jegs)
AFR 205's
Looking to go with 1.6 or 1.7 roller rockers. But I honestly have not a single clue on what kind of cam I need. I want of course the most power, but I've got to have that nice lopy idle. I love the sound of big cams. I hope to have this engine completed by early/mid summer and dropped into the Stang by the end of the season. I hope to make a pass with the 302 and a pass with the 408. That would be awesome.
What do you all think about this setup? What kind of power do you all think i'm looking at? My compression ratio would be right at 11:1 with the 58cc chambers of the AFR's. I would love to get 400hp to the wheels if all possible, but that might be a long shot. My plan is to buy all the stuff, take it to an engine builder and let him assmemble it properly. I'll have A LOT of money in this engine, and I don't want to screw it up, so i'll let a professional do the job.
BLU91
  • Dec 9, 2005
Don't think 400hp will be a problem with mods you have listed. Will you drive it on the street much? If not bump the compression up and go with a soild roller. Carb or fuel injection setup?
I run a solid cam with fully ported TFS highports and a 1020 cfm carb with 13:8.1 compression, but it sees very little street use.
Shadrack
95
  • Dec 9, 2005
Only street driven when I see an LS1 I want to pick on, or occasionally be driven on the weekends as a "cruiser" car. Mainly, the only road driving it may see is when I drive it to the strip and back home.
It will be a carb setup, probably using my holley 750cfm carb if I can use it.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 10, 2005
  • Dec 10, 2005
sounds like a sweet setup. i remeber reading a article in MM&FF where they put a solid roller 292 i believe in the 408 maybe 393 stroker. the cam made insane power. comp cam. that combo can easyly push you over the 500 hp mark probably closer to 550.
RADIALKILLER
141
Arkansas
Dec 10, 2005
  • Dec 10, 2005
Since you are not going to drive it a whole lot on the street, I would go with flat top pistons and a solid roller cam, that is what I did with my old 408 and with victor heads it made way over 400 hp.
Shadrack
95
  • Dec 10, 2005
Well, I don't want to run racing fuel, so that's the reasoning for the lower 11:1 compression ratio. 93 octane pump gas is my goal. I do want it to be street friendly, but it will only be on the street when it is a perfect cruising day. That same website has a 351 to a 426 stroker kit, which puts the compression ratio in the mid 13's.
They also have a 351 to a 427 stroker kit. However, it has hypereutectic dish pistons, and 11:1 c/r.
It won't be on the road a whole lot, but when it is on a the road I want it to be a "street-friendly" drag car. Eventually, I plan on running a TKO 500 tranny with moser axles to take the launches with slicks and hardcore track abuse. The car will be pretty much gutted, so it will indeed be a $h!t-missile and that's what I want.
soontobefastfox
275
Troy, Michigan
Dec 10, 2005
  • Dec 10, 2005
my dad and I built a 351w stroker thats N/A we dont know how much it puts out but its fast. (meaning we havent taken it to the dyno). But it sounds similar to what you want to do.
408 Eagle Forged Stroker Kit
205 Ported AFRs
Comp Xtreme Energy Cam Hydraulic Roller (idk the number, I know the specs though lol)
Cam Specs @ .050 lift
Int Lift @Valve .513 in
Exh Lift @ Valve .526 in
Comp Cams 1.6 RR
Edelbrock Performer RPM Air-Gap Intake
Holley 750 Double Pump
oh and 10:5:1 C/R
and that should cover it...
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
