Well I have decided to build a 408 this winter and have spent a lot of time searching for solid combos. i'm looking for max hp and torque with a flat torque curve for the street. I will run the strip occasionally. Has to be a pump gas motor, we have 92 octane all over nebraska, and only a couple stations with 93octane so I have to consider this into the build.
My foundation, my 1969 9.2" 351 windsor block (hope everything checks out)
11 - 11.5 to 1
Scat internals
TFS high ports OR ported vic jr.s / I would like 300+cfm
Billet Comp solid roller 254/260 @ .050, 600 lift on a 110
Super Victor EFI
possibly a Spyder intake elbow w/90mm Accufab T/B
95mm PMAS velocity MAF
Does everything look appropriate?
I have 30lb injectors that I know will be too small, what size will I need? 50's?
is the compression too high? I was hoping the cam would bleed a little compression off
Which heads would you go with, high ports/ ported vic jr.s?
Any opinions would be great,
Thanks in advance!!!
11 - 11.5 to 1
Scat internals
Super Victor EFI
