I had the unfortunate incident of breaking a valve spring, dropping a valve and destroying a piston, bending a connecting rod, and pushing out the cylinder wall of my block. In other words, I need a new block, valve and springs. I can get a replacement valve, no problem - already got the springs covered as well. As far as the engine goes, I'd like some opinions as to what I am considering.
Cobra crank (out of old motor, no damage)
Replacment Manley H beam rod (other 7 are fine, ordering 1 replacement)
CP forged pistons w/ 9cc dish & rings
Romeo 4.6L Iron block
Cometic head gaskets
DSS Main Support
This is going to run me roughly $1700, not including the new valve and springs, oil, spark plugs, and labor to fix my cylinder head, etc. I was considering an aluminum block but they are going for $1300 and I can't justify spending $1,000 more unless there was a significant difference between the aluminum and iron blocks. Thoughts?
DSS Main Support
