Bulding my first 351 combo help
  • Thread starter Thread starter 98gtvert
  • Start date Start date Dec 9, 2009
9
98gtvert
140
south carolina
Dec 9, 2009
  • Dec 9, 2009
Sup guys, Im working on my first 351. Just bought an 85 gt and decided to go the 351 route. Im gonna keep the displacement at 351 ci for a while and i would love to get 350-375 rwhp and keep it streetable. Gotta 750 carb and edelbrock intake with a 544 lift cam. Really need head help lol. Ive read a lot about 5.0 parts make 5.0 power and i found a set of holly heads cheap but only the 170 cc. Which should i go with. got about 1500 to spend. Thanks
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 9, 2009
  • Dec 9, 2009
1500 to spend, trick flow fast as cast
9
98gtvert
140
south carolina
Dec 9, 2009
  • Dec 9, 2009
Thanks. Do you think that would get me to 375 ish rwhp?
9
98gtvert
140
south carolina
Dec 9, 2009
  • Dec 9, 2009
bump
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 11, 2009
  • Dec 11, 2009
With tf heads the cam intake and carb you said i bet you will be closer to 350 RWHP. I did a 351 and it's 40 over AFR 185 58cc heads trick flow r intake flat tappet cam .499/.522 lift 262/268 duration LSA 112 42# injectors 90 mm LMAF 90mm accufab tb,l/t's.Compression at 8:5.1 or so and i put to the wheels 319/339 on a mustang dyno.Going threw a tremac 3550,spec clutch and 4.10 gears.I was told my cam and low compression killed my numbers?peace
john
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 11, 2009
  • Dec 11, 2009
I think so, if you match the combo well it could make 350 on a bad dyno day and 400 on a real good day
beyondspexj
265
Las Vegas
Dec 11, 2009
  • Dec 11, 2009
john
that low of a compression needs some forced induction.
U
undercnstrction
312
  • Dec 11, 2009
here's a newb question.....what determines what the compression will end up being? am i correct in thinking that the higher the compression the higher grade of fuel will be needed? if pump gas is the goal, you need to keep the compression low (say somewhere between 8.5-9.5)?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 11, 2009
  • Dec 11, 2009
Compression ratio = (displacement+chamber volume)/chamber volume. Displacement = stroke*pi*(bore/2)^2
Chamber volume = piston dish + cylinder head volume + gasket volume + volume above compression ring + deck volume
Depending on a lot of factors, N/A pump gas engines can run as much as 13:1. Normal N/A street engines are usually in the 9.5-10.5 range. Engines on boost are usually 8.0-9.5 range.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 11, 2009
#10
  • Dec 11, 2009
  • #10
I'm gonna have to disagree here, 12:1 is pushing it when it comes to pump gas, esp. todays pump junk, if you were running anymore than 11.5:1 on a street motor your probly going to be sacrificing timing to get it not to ping.
If your building a pump N/A motor i'd stick with 10-11:1, no more or less either way.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 11, 2009
#11
  • Dec 11, 2009
  • #11
Oh I completely agree. I was saying what the extreme limit was on pump gas, not what would be considered "streetable". 13:1 is possible, I had a buddy that competed in HRM's Pump Gas Drags in a nitrous car that was 13:1.
Of course, that car was always giving them headaches.
9
98gtvert
140
south carolina
Dec 11, 2009
#12
  • Dec 11, 2009
  • #12
Guess i need more displacement. thanks guys. With a 408 instead of the 351 how much would it make? im not in a hurry to get it done.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 11, 2009
#13
  • Dec 11, 2009
  • #13
Thats a pretty loaded question, a poorly built 408 could make 375hp, a well built one could be knocking on the 600hp door
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 11, 2009
#14
  • Dec 11, 2009
  • #14
easy now! GEEEEEEEEZZZZZZZZZZ i just got back to work i start monday. The checks will come in,the bills will get paid,the bank will build some what up again,then the snail shell will be going on !peace
john
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
R
Engine Just bought my first 85 fox
  • Rideordie1720
  • May 14, 2019
Fox 5.0 Mustang Tech May 25, 2019
Rideordie1720
R
Engine Thinking About 351, Need Some Help
  • derekleee
  • Oct 10, 2016
3K
Fox 5.0 Mustang Tech Oct 11, 2016
derekleee
Engine Building My First Fox Engine. Need Build Advice.
  • SlugJones
  • Apr 14, 2017
2K
Fox 5.0 Mustang Tech Apr 17, 2017
SlugJones
Excellent Hagerty Article About The "kings Of The Street"
  • FoxMustangLvr
  • Sep 21, 2017
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2017
NIKwoaC
