I took my gas pedal assembly off too. I don't know how you guys got that pin out of there while leaving it on. For the clutch and brake, I put a small amount of soap and water around the edges of the rubber on the pedal covers, and put a small amount of vasoline on the top of the brake and clutch pedals. Start by putting the bottom of the pedals on first, and when it's secure, mash the pedal covers on with your foot and twist back and forth. If you use too much soap and water or vasoline, the pedal cover falls off before you can put your foot on it. It took me a couple tries, it sucked. Oh yeah, be careful while hammering the pin in and out on the gas pedal. It's easy to crack the plastic on the back of the pedal. I accidentally cracked it and had to work some magic to secure the pedal. Again, it sucked.
