Bullitt/Mach1 C pillar swap
No gaps here:shrug:
Im sure that Mach's & Bullits were just painted there from the factory. I think the GT/Cobra/V6 C pillars extended a tad further back, so when removed to add Mach/Bullitt C pillars, it leaves the section exposed....
I wouldn't call it a gap. The Bullitt pillars are shaped differently. The reason for the primer area on the GT's with c pillar swaps is a result of the painting step during assembly. It appears that ford paints the c pillars and quarter panels after they are installed. The stock GT pillars stick out farther on the quarter panel and the Bullitt's are more tapered towards the glass.
I will get some close up pics of what I'm referring to. Give me a couple days with the Holidays and I will have some pics up
Here is another pic example of the erea that will show primer.I did it in black from the paint program....
If you are not picky,on a silver stang,you can get away with it some what.I was doing the install in my garage,and was test fitting everything before i sent mine out to paint,but once i saw the primered area,i was like no way,i could see it in the garage,so i new i would see even more out side in the daylight.It's not a lot of area exposed,but enough for me not wanting to screw with the stock paint,or to install the "C" pillars.So the stockers went back on,and i sold the Mach/bullitt "C" pillars and quarter glass right after.
So basically it depends on the individual.:shrug::)
