DougNuts
Car Nut said:Great chart above!!!
So the Bullitt's front sway bar is 1.5mm larger than the GT, but the rear sway bar is 2mm smaller. Any reason not to switch to both Bullitt sway bars? I would think that they may work well together, but then I've got no real idea as to their exact importance or effect.
How close in specs are the 1994 stock suspension to the GT listed above (which must be a newer GT)?
It's not just size that matters, note that the bullitt front sway bar is tubular instead of solid. It looks like the bullitt suspension has less bar in the rear, but, you have to remember that those sway bars were designed to work with those springs, shocks, and struts. The sway bar is easy to swap out anyway. Try them both and see which one you like.
. Who else would have remembered my ride from gT? Then there was the blown oxfard white GT in your sig, but I already knew who it was before even seeing it.
