Bullitt vs Steeda
Ok it's time for a lil suspension mod's. I have an 01 Bullitt. I want my car set up for mostly street but, also lil auto cross and track days when they come up. So here comes the question. If i went with the set up of having Steeda super-lite sport springs, Steeda X2 ball joint, Steeda bumpsteer kit and adjustable rear swaybar. This should cost around 650$. Now would this be worth it? Please help. Thanks in advance
i'm running the steeda stuff. the superlites, uca's/lca's/ tokico's. I didn't need the X2 balljoints or bumpsteer kit or even castor camber plates. Everything is aligned perfect. The ride is firm but comfortable and the cornering is great. The only problem i have is it lowered just alittle too much for NJ roads...but you'll be fine in Florida. The interstates are flatter and don't have snow/freeze damage.
I'm with tom on this, if you are even considering autoX and open track then the bullitt is no longer an option. steeda, while nice, has become too general in their products, and no longer do they have the flair they used to have in suspension, and engine products.
Tom is right, check into MM. HR Race springs, bilstein dampers, Panhard rod, and steeda LCAs (only because of price).
above all, read EVERYTHING on MMs site. their sheer knowledge is astounding. they know what works, they know how to setup everything, and until the 05 steeda mustang came out with every steeda part made for the 05 Maximum motorsports held the american iron series with their Fox body mustang with suspension mods and a stock drivetrain.
take a look at Toms sig to get an idea of what COULD be done, mine will be similer but not quite the same. my springs, dampers, and LCAs are in the mail now :)
Torinalth
instead of the ball joints and bumpsteer get the full length subframes and strut tower brace. if you are goint to auto cross you will need the camber plates for the camber adjustability to hook up better in the corners.
and do get the sway bar
springs are great from steeda. had them in my 99 offered a great ride need to get a new pair for the 01.
in terms of shocks tokico dspecs are the way to go in term of road racing due to adjustability.
work on the chassis first then the suspension.
yeah, listen to Tom. and i would go with chasis stiffening before suspension stuff. if you plan on auto x'ing at all, go straight to MM. SFC's and STB are a must!
well steeda had the winning driver in the american iron east division last season
http://www.steeda.com/PR/goracing/Grand-Am/rehagen/SeasonWrap-up2004.pdf
bottom line is you cant go wrong with either brand in terms of chassis work and suspension mods.
and btw MM sponsors the american iron series
http://www.steeda.com/PR/goracing/SCCA/tomellis/ellisfirstouting.htm
i havent seen any mm entries in the scca cup. (yet if there were i missed them)
anyways id love to see a heads up road course race between maximum motor sports and steeda
that still would not be the tell all of who has the best parts unless its some sort of 24hrs lemans type race
