Hey - same thing with me. Apparently there's a few batches of mustangs that had the rear axles off by an inch plus. Mine was about 1.25 inches off towards the passenger side. My rear end was in perfect alignment though(wheels tracking perfectly straight ahead but rear axle just sitting off center). No real reason or explanation for why this happens on Mustangs. I think it's a bad frame/body jig for where they add the mounting brackets for the upper control arms. I bought aftermarket upper & lowers and also aftermarket KYB quad shocks which rules out anything being fouled with the suspension or linkage componentry. I should have measured the UCA mounting points' distance from centerline. That is where the problem is, I believe. Anyhow, after all the suspension work my mustang handles great and gets killer traction off the line, but it was still off center. Soooo.....I threw on plate spacers, 1/4 inch, and then a hubcentric spacer on the left side which was 1.25 inches. Now both tires "appear" to be equidistance from the fenderwell on each side. Plus, now I have the wide look in the back, but without the extra weight of deep dish wheels. Win-Win situation. I have 3 hubcentric spacers in 5 bolt pattern for a Mustang, since I only used 1 from the set, so if you would like to purchase one for super cheap PM me. I would reccomend running a 1/4 to 3/8 inch plate spacer underneath since our hub bolts are very long.
