bump compression on 75' 351W
Ive got a 351W im throwin in my 90' Notch. Stock bottom end and conn. rods, bored .040 over with stock flat top pistons. Im trying to decide on a head and piston combo. I was thinking of getting Edelbrock Victor Jr. heads...2.05 and 1.60s. They have 60cc comb. chambers. SO what i wanted to do is swap out the pistons and get the comp. ratio up to 10 or 10.5:1. Does anyone have any recommendations on pistons. ALso, can i just the stock conn. rods. thanks
What I would do...
Shave the heads to reduce the chamber volume, and bump the CR.
Work with what you have now.
jason
EDIT:
Unless there is a decent budget for the build????????
I would not shave the heads because you can mess up the intake alignment. Just doing the heads will get your compression in the 9.5 range, or higher depending on what kind of stock piston you have already. If you really want to get that extra compression, change the pistons and use any flat top piston that has two valve relieves that will get you to the compression you desire (I cannot give any recommendations because there are many out there and I don't know your budget or anything. It would be best for you to contact a place like summit racing to find out what is best.) You should be able to use the stock rods on any piston that has the same pin diameter, but you'll probably have to have the pistons pressed out and the new ones pressed in by a machine shop, unless you can do it yourself.
I just bought a set of forged Keith Blacks for my 351W, shipped to my door for $270. They're also .040. They're the 9925's which should bump my compression with the GT-40P heads to about 10.2:1. Exactly where I want it!
Hey Blue Cobra, what year is your block? Obviously, mine being a '75 is a hydraulic flat tappet. What would be the best route? Keep it flat tappet, go to mechanical flat tappet, or switch it to a roller? I saw in your pics that you had Comp roller rockers so i was just wondering if you had a mid 90's block or did you convert your ol school block. I have also been trying to figure out what heads to go with, i would like to go with the Victor Jrs. so i have room for upgrades and wont have to buy another set of heads later, so the 2.08 and 1.60 valves should be plenty for my plans. My other question is if i put some flat top pistons with dual valve reliefs, will the reliefs be big enough for a 2.08 intake valve? Ive tore apart my 302 HO multiple times, but this is my first time screwing with a flat tappet engine so im trying to get a plan and head in the right direction, because i dont know what i can and cant use on it. any help is appreciated guys!
