  • SN95 4.6L Mustang Tech
Burn out techniques...
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Aug 16, 2004
SilverBullet00
1,150
Wichita, KS
Aug 16, 2004
  • Aug 16, 2004
well, I went to the track this weekend.. My first run was pretty good (see sig), but my second run sucked. On the first run i was able to drive around the water box, and do a light burn out through first gear (holding break). The second run I was on the tower side, which was IMPOSSIBLE to drive around the water box!! I was a little angry having to drive through it, but thought it would be ok, id just do a longer burn out. So when i start spinning, the tires are wet so it goes to red line really quick. I try to power shift into second, but its a no go; All I get is grind, which is extremely embarrasing. So i try and do it again, and i get the same thing: GRIND. By this time i just want to shoot myself because i look like a dumb@$$.
I was wondering if anyone had a better technique? Maybe a more appropriate RPM to switch into 2nd gear (i was doing 5500)? any advice would be great! They arent DR, just street tires (which are crap). Also how hard is this on my clutch? Its not something i would do everyday, just at the track.
V_Eight
617
ATL
Aug 16, 2004
  • Aug 16, 2004
Try dropping it in second instead.
Drag racing kills the car anyways, so dropping second won't be much worse.
steeda46
427
Fayetteville, GA
Aug 16, 2004
  • Aug 16, 2004
I run my RPM's up to around 2500 +/- then drop the clutch and use my left foot to hold the break (one smooth motion). If you play with the throttle you could hold you car in one spot for hours...
A
AcE XBOX
144
  • Aug 16, 2004
I tried second and destroyed the tranny.
M
Matto
287
Arkansas
Aug 16, 2004
  • Aug 16, 2004
Hmm.. well I burnout a lot with burning through first then shifting to second and burning out... is it bad?
onesticker
222
Jacksonville,FL
Aug 16, 2004
  • Aug 16, 2004
Just buy some DR's and forget the burnout.
E
El Diablo
53
  • Aug 16, 2004
Buy a line lock to lock up your front brakes!
BullittStangV8
1,104
NJ
Aug 16, 2004
  • Aug 16, 2004
When i run at the track, i do a 1st gear burn out for about 3 seconds on street tires. If i do it in 2nd gear it gets them too hot and they slip/spin off the line..
As for how to do it, i would start in 2nd, rev it up to 4000+ and pop the clutch. Then get on the breaks just a tad with your left foot to stop you from rolling fowards.
Mike
JimBowy
330
Downriver, Mi
Sep 8, 2004
  • Sep 8, 2004
And I smoked my clutch... (but it was already on its way out...)
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2004
#10
  • Sep 8, 2004
  • #10
Looking at your sig, I would guess that you're running regular radials. In that case, I wouldn't do much of one at all. Just enough to clean the fluff off of the tires....that's it. Heating radial tires up makes them greasy and is actually worse for traction. The only time that I'll heat regular radials at all is if it's a cold day at the track, otherwise...skip the burn out.
Your second run probably couldn't have been saved regardless. Even if you hadn't of heated the tires right up, your front tires probably carried enough water to the line to screw your hole shot anyway. As for your grinding into second......well, that's just you blowing your wad when the pressure was on.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
