Bushed vs. Pressed Rods
  • Thread starter Thread starter str8stang036
  • Start date Start date Sep 12, 2004
str8stang036
1,382
Miami
Sep 12, 2004
  • Sep 12, 2004
Since I am new to this rebuilding engine thing, I have many questions.
What is the difference between bushed and pressed rods? I would think that pressed is what we currently have in our motors correct?
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Sep 12, 2004
  • Sep 12, 2004
The rods in stock motors have the piston pins pressed into them, and the piston floats around the fixed pin.
A full floating pin rides in a brass bushing in the rod that is the same bore as in the piston, and is kept from escaping by snap rings or spiral lock rings in the sides of the piston.
Bushed rods are preferable because the piston and rod can be assembled much more easily without the use of special tools and without the chance of screwing something up, and because a full floating pin will have less wear and friction (an etremely small advantage though), and if excessive load is forced upon the piston, the replaceable rod bushing tends to take the damage rather than the pin bores in the piston.
The use of pressed pins was likely for greater efficiency in mass production of many car engines. They are not used in industrial motors to my knowledge.
Suspension upper axle bushings wont go in
  • Stopman33
  • Mar 4, 2025
Fox 5.0 Mustang Tech Mar 9, 2025
stormsedge
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
