Buying a 1983 Mustang GT, what to look for...
1fast83
West Georgia
This is my first post to StangNet, just registered. I am going to buy a 1983 Mustang GT later this week, I am new to Mustangs, and would like to know if there is anything I should look for before completing the deal? The car is running and driven daily for the most part.
Just curious if there are any spots prone to rust or anything I should be looking for. I plan on parking it in the basement for a while, and dropping in a newly built 331.
Thanks -Joe
Watch all the areas around the windows, especially on the rear hatch for rust. Check inside the cowl (under the wipers), a lot of times non garaged stangs will keep leaves, trash, etc in there and create rust.
If it has had a tranny swap check out the crossmember, did they just weld some crap in there or did they do it right? Can always be changed back to normal or right, but its a bargaining point if its crap.
Check out the torque boxes, a lot of guys wait to late to find out that they are seperating.
Don't let the guy know your doing an engine swap. That way if it's a worn out 5.0 in there, he can't say "well your changing it anyway". Another bargaining point.
Check out the seals around the back quarter glass, more than likely they are starting to go just like the rest of ours.:(
Just a few pointers, I have only been in the mustang thing about 6 months now. I have a lot to learn to, a lot of knowledgable guys on here will chime in I am sure. Overall whatever you get, just dont get in a rush with your projects and have fun.
Mechanical things can be fixed, and body parts are easily replaced. Those things are good for price negotiations, but there are some things that are real deal breakers. Like mentioned before, Really look around the rear torque boxes, where the rear suspension meets the chassis. Check the subframes and the overall straightness of the car. Any rust more than surface rust. Check the rear between the rear glass and the back seat area glass, see if that's twisted. A car that is drag raced hard will usually have it wrinkled up right there. Any of these areas are areas that either can't be fixed, or the amount of time/labor/money to be spent fixing it makes it really not worth it.
you should check for rust here:
-shock towers
-fender antennae
-all 4 points where the roof connects to the rest of the body
-door hinges (where hinge meets body)
-underneath (get that car in the air!)
-and obviously fender & quarters lips
-open the rear hatch and lift up the carpet.
Most important area are the shock towers, floor boards, and truck floor. Areas on the body panels acan be easily replaced or fixed. Rotted towers and other uni-body areas are more serious to get fixed and would actually make the sale void for me.
