Fox Buying An Sn95 5 Lug Swap. What To Look For?
I'm running the Baer dual piston calipers, which I've been told are basically just PBR dual piston. Same as Cobra? So no grinding, hmm?
Have a lifetime Firestone alignment deal. So no worries, there. Thanks, Mike! You're the best!
As far as wide wheels, that is what knowing the offset is for. Think of it as moving the center of a stamped steel rim in or out. If the tire and outer rim fit, you need to order wheels with the Center in the right spot to locate the outer rim in the right orbit.
