Fox TB Conversion Setup - $302
1. Throttle Cable - Ordered $75 1-303-343-7024
2. Throttle Body - Ordered $150 MustangWarehouse.com
3. TFS TB Stud & Gasket Kit - Ordered $20 MustangWarehouse.com
4. EGR Delete Plate - $45 http://www.uprproducts.com
5. Fox TPS and Wire - $5 Junkyard
6. Fox AIC Unit - $7 Junkyard
7. Throttle Cable Braket - $0 Junkyard
Misc CAI After TB intsall $Cheap
1. 45 deg Rubber elbow
2. Straight rubber booty
3. Hard PVC Tube
4. Rubber nipple for TB Connector
5.0 Motor Build Up $2195
Jeff Owner of mustangwarehouse.com
1. TFS-K514-350-370 TRICK FLOW ENGINE KIT $1700
1.) TFS-51400004 Cylinder Heads, Aluminum, Natural, 61cc, Ford, Sma...
2.) SUM-G6620 Timing Chain, Double Roller, Steel Sprockets, Ford...
3.) TFS-51400904 Gasket Set, Head Set, Ford Small Block Windsor, De...
4.) TFS-51400004 Cylinder Heads, Aluminum, Natural, 61cc, Ford, Sma...
5.) TFS-51400510 Rocker Arms "CNC Machined" 1.6 Ratio 3/8" Stud SB ...
6.) TFS-51400801 Valve Covers, Stock Height, Cast Aluminum, Silver,...
7.) TFS-21406700 Pushrods, Chromemoly, 5/16 in. Diameter, 6.700 in....
8.) ARP-154-3601 Cylinder Head Bolts, High Performance Hex, Ford 28...
2. Valve Cover tube & Breather for new Valve covers. $25
3. 24LB Injector 45 PSI Set FMS-M9593A302 mustangwarehouse.com $220
4. Maf & Filter #80PN2V $250 or $330
5. Trickflow Upper Intake hardware kit TFS-EFIKIT1 $25
or Inch spacer $60 (to take off valve covers)
New Mac Exaust $460
1. Long Tube Headers $240
2. Pro-Chamber $222
Should i get the 1 Inch spacer, he said that way i can take off my vavle covers with out taking the upper off.
Will i loose performance by doing this?
O and i think i need lifters don't know what kind please help me out.
3. Hard PVC Tube
New Mac Exaust $460
2. Pro-Chamber $222
