Buying TB 4 Exploder Intake 2nite...
  • Thread starter Thread starter Strype
  • Start date Start date Apr 24, 2006
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 24, 2006
  • Apr 24, 2006
I have a 75mm TB/Spacer and Explorer Intake that came with my car... I'm transfering it to another.
Questions:
1) Should I buy a 65mm TB/Spacer since that's what size the Explorer intake is (I think)???
2) The Explorer intake is lacking an EGR related hole apparently that the stock intake has... Should I take off my EGR? I have a device that sends a fake signal to the computer.
Thanks guys!
Maryland Stang
1,656
30
39
Greenville, NC
Apr 25, 2006
  • Apr 25, 2006
Measure the Explorer and see what size it is. If it's smaller than 75mm and you don't want to port it out then buy the correct size spacer and TB.
You can remove the EGR valve in this case but make sure you use a non-EGR spacer or block off the spot on the spacer where the EGR was. A tight fitting gasket is required. The spacer is required since it holds the throttle cable.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
Engine GT40 Tubular Intake Install Problems....
  • daredevil95
  • Oct 1, 2022
5K
Fox 5.0 Mustang Tech Oct 15, 2022
daredevil95
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
Explorer Throttle Body on 94/95 w/Fox TB conversion?
  • doctorj357
  • Aug 8, 2021
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Sep 11, 2021
KRUISR
