Buying TB 4 Exploder Intake 2nite...
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
I have a 75mm TB/Spacer and Explorer Intake that came with my car... I'm transfering it to another.
Questions:
1) Should I buy a 65mm TB/Spacer since that's what size the Explorer intake is (I think)??? :shrug:
2) The Explorer intake is lacking an EGR related hole apparently that the stock intake has... Should I take off my EGR? I have a device that sends a fake signal to the computer. :shrug:
Thanks guys!
Measure the Explorer and see what size it is. If it's smaller than 75mm and you don't want to port it out then buy the correct size spacer and TB.
You can remove the EGR valve in this case but make sure you use a non-EGR spacer or block off the spot on the spacer where the EGR was. A tight fitting gasket is required. The spacer is required since it holds the throttle cable.
