  • 1994 - 1995 Specific Tech
Bypass smog pump on 95 Cobra
  • Thread starter Thread starter 95riosnake
  • Start date Start date Mar 4, 2006
First Prev 2 of 2
95riosnake
630
Pittsburgh, PA
Mar 8, 2006
#21
  • Mar 8, 2006
  • #21
Green 94 5.0 said:
if you take the smog pump out, you can remove everything. on mine, the tube going to the heads are completely gone and the holes are plugged, the pump is replaced with an idler, all the vacuum lines are either removed altogether or plugged, and the tube going to the midpipe is completely gone as well. mine wasnt removed for a performance gain, but more to clean up the engine bay of unnecessary stuff since i no longer have cats and the smog pump wasnt providing any benefit to the cars longevity. the smog pump doesnt put much drag on the motor. if emissions necessity needs you to have it, i would just hook it up normally and leave it alone since you wont notice any gain at all by removing it.
the reason I am bypassing the pump is that I don't want to go through all the hassle of welding, bending, tweaking the tube to feed the oxygen to the exhaust, especially for something that is totally unnecessary now that I have no cats, and havent for 3 years now. I went through all that trouble when I got the BBK O/R H but don't wanna do it again.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Mar 8, 2006
#22
  • Mar 8, 2006
  • #22
strange. mine actually lined up perfectly before i removed the tube. it would have taken about 4 inches of heater hose to have made mine connect.
9
95mustang_gt
364
Wisconsin
Mar 8, 2006
#23
  • Mar 8, 2006
  • #23
i tryed a smaller belt today but i couldnt figure out how to get it tight with the tensioner pulley?What did you guys do about that.I hope this aint a dumb question.
i want to bypass mine for the same reason as 95rio.i want to get rid of the smog pipe by the exhaust and the other.
if anyone has a pic showing the belt off the smog pump and just around the others,that wil be nice
thanks
Jesse
gcomfx.com
3,690
Republic, MO
Mar 8, 2006
#24
  • Mar 8, 2006
  • #24
I removed mine because my EGR started sticking. The car would run funny and you could see the plunger not moving like it should poke it with a screwdriver and it would move and start working again.
It was cheaper and easier to work on the car without it there. I just recently found a new solution to cap the manifold bung, and set the EGR sensor where it won't trigger the Check Engine Light.
Labora
1,854
26
69
Dallas, Texas
Mar 9, 2006
#25
  • Mar 9, 2006
  • #25
mricci said:
You can just bypass the smog, i have had mine bypassed for a long time with no problems, not sure about it seizing up though. But the belt will be fine just bypassing it.
WRONG!
IF YOU OWN A COBRA READ UP.
You cannot just run a short belt and be done with it.
Thanks to Ford adding a Oil cooler of sorts (or a oil heater in most conditions IMO) You WILL have to remove the oil cooler lines or they will rub on the belt when you route it without the smog pump.:SNSign:
You guys with GT's don't know of the PITA that is moving the oil cooler lines. Be glad...
mricci
301
Massachusetts
Mar 9, 2006
#26
  • Mar 9, 2006
  • #26
oh, sorry for the misinformtation, i had no idea the cobra had that. Ill keep that in my head about cobras for now on.
Pokageek
2,767
MA, USA
Mar 9, 2006
#27
  • Mar 9, 2006
  • #27
Back to the pulley....
mricci
301
Massachusetts
Mar 9, 2006
#28
  • Mar 9, 2006
  • #28
I used a small belt that bypasses the idler pulley, smog, and ac, but the only one i could get the tensioner bottoms out and you can here it hitting itself. Heres the part number from autozone. 812k6. A good thread with tons of info on this is http://forums.stangnet.com/showthread.php?t=521165
95riosnake
630
Pittsburgh, PA
Mar 9, 2006
#29
  • Mar 9, 2006
  • #29
Welp, Labora was right....the oil cooler lines are definitely in the way.
so....no short belt for me, and I'm not willing to take the smog pump off. I made the factory smog tube work with some hi-temp silicone heater hose.( )
95cobraguy
637
11
Concord, NC by way of LI, NY
Mar 9, 2006
#30
  • Mar 9, 2006
  • #30
if your worried about cleaning up the engine bay that oil cooler mess should be the first thing to go. i noticed absolutely no difference in oil temp with that thing removed.
Pokageek
2,767
MA, USA
Mar 10, 2006
#31
  • Mar 10, 2006
  • #31
Not to press the issue by why won't you just use the pulley and get all that crap out of your way in the engine bay?
95cobraguy
637
11
Mar 10, 2006
#32
  • Mar 10, 2006
  • #32
i used the pulley also for the ac and smog pump. it cost more than just using a short belt but it beats making a million trips to the parts store to match up a belt. by removing all the smog gear it definetly cleaned things up.
95riosnake
630
Pittsburgh, PA
Mar 10, 2006
#33
  • Mar 10, 2006
  • #33
Cuz I am graduating college in 2 months, and don't know what state I will end up in. If the state has emissions I will need the smog pump and I don't wanna have to go through the hassle of reinstalling all that. If I end up where they don't have emissions testing, I probably will end up removing all of it.
mricci
301
Massachusetts
Mar 10, 2006
#34
  • Mar 10, 2006
  • #34
I would just wait then and find where you are going then decide what to do.
9
95mustang_gt
364
Wisconsin
Mar 10, 2006
#35
  • Mar 10, 2006
  • #35
i ran a shorter belt today and bypass the smog and ac.my question is that i felt a little backpressure at wot.what could of cause that.
thanks
Jesse
HISSIN50
34
129
Mar 10, 2006
#36
  • Mar 10, 2006
  • #36
thanks
Jesse
What does backpressure feel like? If you want to check for an exhaust restriction, you can hook up a vac gauge. Hold the RPM at 3K rock steady (while stationary) and watch the vac gauge. If the reading drops after 30 seconds or so, that indicates an exhaust restriction.
First Prev 2 of 2
Fox Help my smog pump :poo: the bed.
  • nickyb
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2025
nickyb
Smog pump bypass?
  • PvolkStang
  • Apr 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
nickyb
V
Okay for smog pump to spin?
  • Valicy
  • Sep 28, 2024
1994 - 1995 Specific Tech Sep 28, 2024
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
