Bypassing the factory Amp in a '91
Londonbroil
Background, I have a 91 Mustang, with the factory 6-Speaker setup (2 in dash corners, 2 in the door, 2 in the rear seat area).
The old Sony receiver I had was recently stolen. Its not all bad, it had intermittent sound to some of the speakers and featured a cassette deck!
I purchased an Alpine 9857 deck, and I assumed (bad me) that it would be plug and play just as the Sony was. No dice. Inspecting the harnesses in the radio area, I noticed that the factory feeds to the amp use a single common ground. This evidently won't work with the new deck as I plugged it in and no output (I tried CD and radio to be sure it wasn't one or the other).
Is there an easy (I am lazy) way to get this working without resorting to new wires to all the speakers, and/or installing an amp? I am really against installing an amp, but if push comes to shove I guess I will do it.
Any shortcuts you guys can think of will be greatly appreciated.
Thanks
I just installed a new stereo and I bypassed the factory amp using a wiring harness from crutchfield.com. If you add a highend stereo to a cart for your car, it will show you all the adapters you'll need to install the deck. Once it does that, just click on the wireing harness in the cart for more information. Also, once you know which harness to buy, you can get it at Bestbuy or the like...
Thanks I may try that, but the more I think about it, the more I think I will just rewire the entire thing. I have to pull it all apart to replace the "high-end" paper cone speakers anyhow.
High End Paper Cones...LOL. I feel ya, when I bought my 96 coupe, the previous owner had removed the mach 460 system, stuck in a broken ford tape deck and didnt even bother to wire it up. I figured all I had to do was get a new radio and plug in the harness, nope. The wiring was butchered everywhere. So I re-wired everything and even replaced the speakers while I was at it. Took a good part of the day, but was happy with the end result. Adding amps later was fairly easy since I had prewired everything.
