C-4 help!
  • Thread starter Thread starter bigblokstang
  • Start date Start date Feb 15, 2004
bigblokstang
94
  • Feb 15, 2004
I just picked up an early model c-4 that has been rebuilt, and a 2800 converter with a shift kit...but anyway, what i am wondering is, this is one of those that when the selector is placed in drive, it starts out in 2nd gear. the only way to get "low" first gear is to manually shift it down. i guess my question is can you just replace the valve body with a later model one that isnt set up that way?
the trans works great, shifts hard....but there are times you dont feel like manually shifting it, and i am afraid it will generate alot of heat and premature wear by it starting out in 2nd all the time.
any info would be appreciated!!
thanks!
hllon4whls
BANNED
2,567
Covington
Feb 15, 2004
  • Feb 15, 2004
It should always start in 1st from a dead stop. If you crawl along, they will usually shift to second at a low speed if there is no load. Then they dont downshift to first unless you are at rock crawling speed.
Some C4's when put in second, will shift from first to second auto matically. At least that was the way the one in my 80 F100 worked.
G
gopher_6_9
55
  • Feb 15, 2004
Shift kit is your problem. The c6 in the f-150 I am driving right now while the ranger is down is like this, it is caused by the cheaper shift kits (B&M and TCI etc), you get used to shifting manuelly. I am telling you though get a TCI street strip valve body, you won't regret it the ranger is badass with it.
NKau
1,346
Jefferson, WI
Feb 15, 2004
  • Feb 15, 2004
Would this by chance be a '65-'66 C-4?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 15, 2004
  • Feb 15, 2004
My C4 does that, but i think if you pay super close attention you might notice it in 1st for a short while before it hits second? Mine is only in first for like 10 feet, i'm guessing because of my gear, but it's all second after that. Personaly i hate it with a passion, and i'm putting a 5 speed back in it this spring.
289Mustang
11
  • Feb 15, 2004
Early model C4s up to '66 would have a shift pattern like 2-D-1, my 66 has this setup.
All C4s after 66 should have the normal D-2-1 shift pattern.
bigblokstang
94
  • Feb 15, 2004
I think it came out of a late 64 galaxie with a 289.
the owner was a relative of mine, and he said that it has always done that (start in 2nd) even when it was totally stock. I just wasnt certain if a newer style valve body would go into the early model c-4's w/o problems.
NKau
1,346
Jefferson, WI
Feb 15, 2004
  • Feb 15, 2004
Yeah, you want to go ahead and put a '67 or later valve body on it. No problems that I'm aware of.
ashford
485
fargo ND
Feb 15, 2004
  • Feb 15, 2004
the only tranny i know of that takes off in 2nd gear in drive was the cruisomatic, if put in 2nd gear it got a 1-2-3 shift to it.
bigblokstang
94
#10
  • Feb 16, 2004
  • #10
thanks NKau.
i appreciate all the input from the other members too!
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
