E Eyeless_Seven New Member Sep 30, 2006 57 0 0 Nov 28, 2006 #1 Nov 28, 2006 #1 Will a c-4 from a 1966 289 fit behind a 1966 6 cylinder?
brianj5600 Active Member Sep 19, 2003 1,964 2 39 Middle TN Nov 28, 2006 #2 Nov 28, 2006 #2 Yes if you change the bell housing. Also if it has the same shifter arm. If not you have to pull the valvebody to change the shifter arm.
brianj5600 Active Member Sep 19, 2003 1,964 2 39 Middle TN Nov 28, 2006 #3 Nov 28, 2006 #3 And the converters are different, but interchange.
E Eyeless_Seven New Member Sep 30, 2006 57 0 0 Nov 28, 2006 #4 Nov 28, 2006 #4 Thats great ! Thanks guy's for the fast answer . They are both out of 66 Mustangs. Will be installing the v8 c-4 to the straight 6 this weekend. Bad new is I lose 20.00 to my Ex father in law. :SNSign:
