C&L MAF
raulbadillo
51
Guys im just wondering, i bought a MAF unit and just wondering if I have to use the original sensor from my old unit. its a 73mm unit. I put 24lb injectors and was wondering how it was to be calibrated for those injectors if im using the original sensor from my old unit? The MAF and injectors i bought together from the same guy who had them on his car. Did he forget to send me the sensor that screws into the top? or am i supposed to use the original unit off my stock MAF?
Your suppose to reuse the stock sensor and just screw it into the C&L housing. There should be a small tube inside the C&L housing, that is what "calibrates" the MAF. If your running 24 lb injectors the tube should be blue, I can't remember exacly where on the tube its marked though. If you don't have the tube you can buy one from anyone who sells C&L stuff for like 30 bucks.
This is what it should look like.
