  • 1994 - 1995 Specific Tech
C&L or Pro-M???
  • Thread starter Thread starter 89 ST4NG
  • Start date Start date May 21, 2009
89 ST4NG
36
Virginia
May 21, 2009
  • May 21, 2009
Just curious I need a new air intake system since the majority of my was busted in a wreck so I might as well do it now since were about to get the car fixed.
Should I get a C&L kit with the inlet pipe, MAF, and the filter kit or a BBK CAI with a Pro-M MAF???
I'd just like to see what your inputs would be and your experiences with each?
earleys94gt
1,223
Ashley, Ohio
May 21, 2009
  • May 21, 2009
My opinion, I like the C&L more than the BBK. It looks cleaner, and it comes in a kit.
The power gains you see from the install will depend on the other mods you have on the car.
ProKiller
3,064
15
78
PA
May 21, 2009
  • May 21, 2009
cold air is a cold air is a cold air.....
now the MAF is important. i don't like c&l. heard too many stories of them not agreeing with our cars. some have had success, others haven't. too much chance for me to place my faith in them. i was one of the lucky ones when i had mine, but have since switched to an 80mm pro-m and won't go back. if i ever do get another one it would probably be an abaco
Venom351R
4,548
41
98
MAINE
May 21, 2009
  • May 21, 2009
Best..... DBX Meter
Good...... PRO-M
Blah......... C&L
T
tjh566
608
Northern Va
May 21, 2009
  • May 21, 2009
C&L isn't that great, i wouldn't go there, pro-m is the way to go.
With the C&L meter it just restricts airflow to the sensor and commonly has problems when tuning the car.
The Pro-m is a new sensor calibrated for the car and comes with a flow sheet, hang onto this sheet in case you want to tune in the future.
As for the CAI any ol' CAI will do. I got the BBK awhile back and was very satisfied with it.
89 ST4NG
36
Virginia
May 21, 2009
  • May 21, 2009
I was leaning more toward the pro-m and a bbk CAI or jus any ole CAI but C&L looks so clean.
Another thing does it matter wat mm TB I use? whats is the stock TB size? and I am planning on adding some bolt ons in the future; like pulleys, fuel pressure regulator, the portin the intake. are these things to consider with a TB size?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 21, 2009
  • May 21, 2009
Two things to consider here
1) The CAI
2) The meter
As for #1 ........
More bends offer more restriction
Ambient temps effect it very little at WOT so it being made of metal of plastic
does not make much difference
Drawing in cool air from outside the hot engine compartment is the main
thing to look for with your intake piping system
If the outside temp is high ... You most likely won't notice a power gain
2) Without knowing your mods ... I can't reply with much intellengence
but ... If you are stock or close to stock ... A meter is not gonna help you
If talking ProM ... a 19# caled meter is like a screen door on a submarine
and
If you do more mods later which require larger inj's ..........
You would have to have it recaled
I'd suggest you create a sig with all your mods listed
then
All the members can answer your Q's more effectively
and
You will get more response when you post up Q's
Grady
89 ST4NG
36
Virginia
May 21, 2009
  • May 21, 2009
OK so I guess ill jus buy a CAI then worry about the MAF and TB later after other mods.
and a regular CAI only has one bend and a C&L has 2 if im not mistaken.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 21, 2009
  • May 21, 2009
Redline_351R said:
Best..... DBX Meter
Good...... PRO-M
Blah......... C&L
Best: Abaco DBX/SCT BA series
Good: LMAF
Blah: Pro-M/C&L
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 21, 2009
#10
  • May 21, 2009
  • #10
I've always had good luck with Pro-M, but I thought they went out of business or got bought out or something.
Kurt
89 ST4NG
36
Virginia
May 22, 2009
#11
  • May 22, 2009
  • #11
So many choices so little money LOL
T
tjh566
608
Northern Va
May 22, 2009
#12
  • May 22, 2009
  • #12
Good: LMAF
Blah: Pro-M/C&L
Pro-M is decent dependent upon the application, I agree that the good/best choices are better but they also require a tune which is even more $$$
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 23, 2009
#13
  • May 23, 2009
  • #13
Pro-M is a bolt on.
Kurt
9
95 Green GT
#14
  • May 23, 2009
  • #14
well ive got the c&l maf and flow tube and my car it mostly stock but when i put it on i noticed a little gain. plus it looks good so i say c&l unless you are going bigger inj's a c&l is not a good idea.
TrueBlue95GT
966
Connecticut
May 23, 2009
#15
  • May 23, 2009
  • #15
Kurt
They went out of business and a couple of the employees branched off and started PMAS...Professional Mass Air Systems.....which is basically the same product.
earleys94gt
1,223
Ashley, Ohio
May 24, 2009
#16
  • May 24, 2009
  • #16
Just make your own.
http://forums.stangnet.com/383803-looking-pics-homemade-cold-air-inductions-kit-2.html
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 26, 2009
#17
  • May 26, 2009
  • #17
Thanks for the update. I was out of the loop, and didn't know what happened to them. I've always liked Pro-M, so now I know where to go if I need another MAF.
Kurt
TrueBlue95GT
966
Connecticut
May 26, 2009
#18
  • May 26, 2009
  • #18
Kurt
Ya, same here. The car has been off the road for a good 5 years and I just got mine up and running again. Not running well, but running...should be fun when I can get it tuned.
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
T
A/C Compressor Reliability with Supercharger Setup – Need Advice
  • ThotTrap
  • Aug 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 29, 2025
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
