- Aug 12, 2003
- 33
- 0
- 6
I've had the C&L plenum joined with the stock TB for a few months now and everything's been ok. But yesterday I removed the stock TB only and installed the AccuFab 75mm TB.
The plenum was left alone, I did re-use the stock plenum/TB gasket, and I did re-check all my inlet connections - all are good and tight.
However, with this new setup I can hear a distinct slurping sound when on the gas, even just a little bit.
My question is for others with this setup: Is this new 'slurping' sound with this combo normal or does it sound like a leak?
(Thought I'd ask others before I tear it apart just to find out it's normal.)
Thanks in advance
Thanks in advance
, is the noise it makes, not a leak.
