  • 1994 - 1995 Specific Tech
c&l question
  • Thread starter Thread starter DarkProphet
  • Start date Start date Jul 24, 2005
DarkProphet
391
Quakertown, PA
Jul 24, 2005
  • Jul 24, 2005
my friend gave me his 73mm c&l maf from his fox body. it doesnt have a flange on it, which doesnt matter because of my supercharger piping. I know i have to change out the sample tube as well, Do i have to change out the electronics on it as well? the part number of the sensor on the maf now is different from the stock maf electronics. Its not a big deal to change it, i just dont know if i need to?
18mustangs
533
Virginia Beach, VA
Jul 24, 2005
  • Jul 24, 2005
If you want to use a Fox MAF sensor on your car you must verify that the two used the same part (I have no idea if they do). It is possible that they used the same sensor, but I'd ask Ford first anyway just to be safe. Personally, your MAF sensor is not as old as the Fox's MAF sensor so it's probably best to use your electronics. From your post I know that you are aware about the different sample tubes, you can get it here: http://www.cnlperformance.com/calibration.html mine was $36.00 after shipping.
Tim
M
Muy_Pyro
52
Flint, MI
Jul 24, 2005
  • Jul 24, 2005
I'm pretty sure you still just use the stock electronics. The sampling tube should be the only difference. C&L is made to run off the stock electronics, I don't even know what else you could put in.
DarkProphet
391
Quakertown, PA
Jul 24, 2005
  • Jul 24, 2005
well the electronics from his 91 are in there now, I could put my electonics in easily as it is only two screws, but i was just checking, i wasnt sure if the c&ls came with a different type of electronics in it for some reason. Ill just take his out and put mine in to play it safe.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
