c&l trueflow install ?
This same topic came up in the Mach 1 section. I don't know why you would want to use the stock MAF if you bought the whole Tru-Flo Intake, but I guess people are trying to do that. From what was said, the stock MAF matched with the Tru-Flo kit won't fit. Or if it does, it will be a beotch to fit. Just use the whole kit. You can install it in about 15 minutes or so.
*Edit. If you just want to use the inlet pipe I'm sure that will work. I did'nt look at the website you had posted. I was thinking you had the whole kit with the C@L MAF and the conical filter and housing also.
